Previous in Forum: Generator-High Temperature   Next in Forum: 2000 Chevy Cavalier 4 Cycle 2.2 Engine Light On
12 comments
Double Acting IC Engine
08/02/2011 11:16 AM
I am doing final year project as "Double acting ic engine", But i can't get more information about this topic. So please send some idea about this topic & also manufactring cost for this engine.
Re: Double acting ic engine
08/02/2011 11:19 AM
This is CR4, not McDonalds (other fast food outlets are available)!
08/02/2011 11:24 AM
The purpose of these projects is not to teach you how to have others do your work for you. For that, you'd need to be taking management courses.
Do your own work. If your learn how now, you might succed when you get a real job.
Good luck, now go forth and research.
08/02/2011 11:32 AM
While agreed it's not cool to ask other to do your homework, read on the Chieftain Main Battle tank's engine. It might lead you to some similar resources.
08/02/2011 11:42 AM
The Leyland L60 of the Chieftan Tank is an opposed piston engine. Different idea.
08/02/2011 7:28 PM
If you answer this question, I may help you.
What is the power output of your engine?
08/03/2011 12:06 AM
approx 1.5 or 2 times double the same cc of engine and also less space, more powerful than same capacity of engine.
Good Answers: 137
08/03/2011 7:40 AM
That's not quite what lyn asked.
Most steam engines were/are double acting. Double acting ic engine has been considered before, but I don't know of a successful one being built. There are advantages, but plenty of practical problems, one being that it needs a piston rod as well as a con-rod.
Codey
08/03/2011 10:13 AM
I believe model builders are building real small ones.
I'm just opposed to doing people's homework for them, if they don't have a clue. What will they know when done?
Cheers.
08/04/2011 10:38 AM
Here is a drawing of a double acting engine that was used in, of all things, an airplane. This is from 1932. Looks like a LOT of moving parts.
Good Answers: 123
08/09/2011 10:34 PM
If all you want to do is double power output, simply convert to 2 cycle design.
Bob
08/02/2011 11:36 PM
What happened when you Googled "Double acting ic engine?"
08/03/2011 12:03 AM
Some thing picture of double acting engine is displayed. But i can't get more information.
Register to Reply 12 comments
bob c (1); Codemaster (1); Doorman (2); lyn (3); PWSlack (1); sarab_deo (2); Silverbug (1); woodpower (1)
