Previous in Forum: Punching Operation   Next in Forum: Baking Oven
India - Member - New Member
CNC Surface Grinder
08/03/2011 7:13 AM
any body tell me how to convert conventionl surface grinder to CNC surface grinder
Good Answers: 97
Re: CNC Surface Grinder
08/03/2011 1:56 PM
What make and model do you have?
To convert you need to replace the hand wheels with steppers or servos. and instruct moves by getting the motor to move any distance , direction or speed.
You can use movement controllers like Galil or even software drivers like Mach 3,
If you can get hold of an old plotter (usually over-designed steppers) you can drive
the movement by simple HPGL or similar commands.
