Previous in Forum: Tie-In Points   Next in Forum: Power Consumption of Computer
Calculation to Find KVA
08/08/2011 2:00 AM
hai frnds...
i have 1000kva delta-star transformer... primary volt is 6.6kv and primary full load current is 87.5 amps
secondary volt is 433volt and full load sec amps is 1334.4 amps....
p=1.732*v*i tis equation is for both delta as well as star... to measure kva....
my question is why ve are using 1.732 common for calculating both star and delta..????
Re: calculation to find KVA
08/08/2011 2:16 AM
The "phasor diagram" describing a 3-phase network is an equilateral triangle plus three line segments joining each vertex to the center. From geometry, the sides of the triangle are √3 x the lengths of the vertex-to-center segments. 1.732 is a rounded-off version of √3.
08/08/2011 4:44 AM
tnks for ur reply friend pls explain in detail please....... iam not getting the correct point what ur are mentioning.... pls eleborate me..... if u have daigram it will be help full for me frnd friend to understnd...
08/08/2011 6:29 AM
normally 3 phase power = 3*Vph*Iph
in star, Vline = 1.732 * Vph so 3*(VLine/i.732)*Iph
In delta, Iline= 1.732*Iph so 3*(ILine/1.732)*Vph
so both connection power = 1.732*VLine*ILine
Register to Reply 3 comments
mohsinhamid (1); th.sulthan (1); Tornado (1)
