Previous in Forum: Calculation to Find KVA   Next in Forum: Timer Relay
Power Consumption of Computer
08/08/2011 2:03 AM
Sir,
Can anybody please tell me the maximum power consumption of computer with 19"inch LCD monitor.
Re: Power consumption of computer
08/08/2011 2:08 AM
If you try hard enough, you can probably find examples of 1000w or more....
Good Answers: 82
08/08/2011 3:20 AM
I'll say under 200 watts. My four-core i7 tower with three hard drives normally takes about 120 watts, and a 19-inch LCD monitor should be under 75 watts.
Thanks, Win
08/08/2011 4:09 AM
The power rating will be found on a manufacturer's label attached to it, probably near the power inlet socket.
Good Answers: 44
08/09/2011 11:57 AM
Ahhh--yup.
Good Answers: 44
Re: Power Consumption of Computer
08/09/2011 12:50 PM
If you want real world, you will have to measure it. The mfr label, as suggested, is the lab value so engineers can plan accordingly for building and UPS loads, etc.
A general answer cannot be given because we don't know what type of power you are using, what power supply each PC/Mac uses, how many hard-drives, what type of motherboard, what the power usage scheme is, etc.
There is a lot of information which goes into this calculation, but simple measurement with the terminal running at some variance of maximum capacity would be a good start.
cuba_pete (2); PWSlack (1); Tornado (1); Winfield Hill (1)
