In my home I am facing problem of less voltage(often 199VAC).My desktop motherboard burned due to this voltage fluctuation.The UPS connected to the system showed 240V when i measured with a multimeter at an instant then going back to 200V(difference of 40V) with a ticking sound of relay.
I observed the voltage hike is when the incoming supply is less than 199V.So it is automatic voltage stabilizer cum UPS.
I am thinking to call the UPS service centre for some help.I cant blame them for this problem but i wonder if at all they can change the settings of UPS so that i can get a constant voltage with less voltage variation.
Can i use an autotransformer of rated capacity with a voltmeter to adjust the voltage to 230V?
Is there a voltage stabilizer which varies its voltage without any switching operation?
