Previous in Forum: Hydrotest Pressure   Next in Forum: Inspection Test Plant
10 comments
Rubber Lining in Electric Resistant Welding
08/15/2011 4:26 AM
what are advantages and disadvantages of Rubber lining in ERW pipes ?
Thanks in advance for the reply
Re: Rubber lining in electric resistant welding
08/15/2011 4:30 AM
The advantage is corrosion resistance. Rubber-lined pipe is often called into service where plastic pipes cannot be used for process considerations. There days, it is often a last stop before selecting borosilicate glass pipe systems.
The disadvantage is it cannot be welded or machined without significant risk to the factory-made component's corrosion resistance.
08/15/2011 4:35 AM
Thank you for your reply
what is the advantage of rubber lined seam less pipe over rubber lined ERW pipe?
08/15/2011 5:22 AM
What is the corrosion risk from the external atmosphere?
08/15/2011 5:26 AM
it is for internal rubber lining
08/15/2011 5:36 AM
08/15/2011 5:44 AM
AWOOGA AWOOGA
Do loop alert, evacuate this thread immediately.
So I went into the chip shop and said cod and chips twice.
He said
I heard you the first time.
08/15/2011 5:57 AM
Oh, no. Not more Tommy Cooper jokes <sigh>?
08/15/2011 7:46 AM
If there is no significant enhanced external corrosion risk then there should be practically no difference in performance between the two types of pipe. Some client organisations, however, may introduce restrictions on the one type or the other for reasons best known within, therefore follow the client piping standards in selecting components for the piping system desired.
08/15/2011 7:02 AM
painting can be done for external protection
Re: Rubber Lining in Electric Resistant Welding
08/15/2011 1:54 PM
rubber lined erw pipe: almost same as strong as the seamless; same cosessive resistence as the semaless; easire to make, thus less costly than seamless.
as rightly said earlier by PWSlack follow the clients spec...
Register to Reply 10 comments
mahesh_4754 (1); PWSlack (5); shafeeque (3); user-deleted-1105 (1)
