Previous in Forum: Usage of Aluminum Alloy 7075 T6/T651   Next in Forum: Road Work
9 comments
Acoustics - 850 kva Generator
08/16/2011 4:57 AM
Hi !
we have 850 kva generator to be installed in the city center and the generator is making a lot of noise which is much above the muncipal permissible limits. Now i wanna make the generator room sound proof to reduce the sound coming out. Please suggest me what material and how i have to constuct this room.
Thanks
Re: Acoustics
08/16/2011 5:03 AM
Marine acoustic engine compartment insulation applied to the walls and ceiling worked well not far from here.
Good Answers: 181
Re: Acoustics
08/16/2011 5:36 AM
Just keep in mind heat dissipation. OK, so you're set is now nice and quiet, but cooking it's self to death!
To be honest there are companies out there that will design and guarantee their work, give some of them a call.
Good Answers: 266
Re: Acoustics
08/16/2011 6:56 AM
Good Answers: 918
Re: Acoustics - 850 kva Generator
08/16/2011 8:15 AM
What you use will depend on the environment of the room (humidity, etc.). Typically, these rooms are simply cement block rooms that amount to an echo chamber. You need to convert the acoustic sound to heat ultimately rather than have it bounce around until it escapes to the outside like it does now.
Many tricks can be used. One trick is to build an inner wall and ceiling inside the existing room to isolate the outer wall.
The wall should be isolated mechanically from the outer wall and fiberglass insulation batting placed between the two walls.
I would use drywall on the interior wall surface, possibly two layers (adding Green Glue between the drywall layers - more later).
If an interior wall is not possible, a second layer of drywall with a viscoelastic constrained layer of a product called Green Glue should be applied as per manufacture's direction. This will suppress a lot of noise.
Another product is Owens Corning 703 fiberglass panels. 4" thick panels will absorb sound very effectively. Optimum installation would be to suspend these panels away from the walls to act as a bass trap. The one issue is that these panels are also a potential mold trap if the room has moisture in it. [p[] Of course you can use a combination of the solutions I have cited to increase absorption.
You will also want to treat the inner surface of the room's door so it doesn't broadcast noise.
Lastly, a good muffler will quite the exhaust.
08/16/2011 9:29 AM
I used to work for a company that developed and built electronic mufflers. They work!
Active Exhaust Noise Cancellation - Clemson Vehicular Electronics ...
Good Answers: 150
08/16/2011 11:44 PM
Start by mounting the genset on a vibration isolated (spring or cable type isolator with a low enough natural frequency so it won't go into amplification) subframe. a lot of low frequency energy will be conducted through the floor/foundation and low frequency will travel a really long distance and has a lot of power under that waveform curve. All the insulation on the walls in the world won't do jack to prevent conduction through the ground. You'll need to use a bellows on the exhaust piping probably to keep the genset movement on the isolators from busting the plumbing.
Who is John Galt?
08/17/2011 2:50 AM
Hello, all hints given are correct. There are excellent mufflers available for the exhaust, there is sufficient damping of the engine noise inside the engine room.
But as the engine with 850 kVA will have an big air intake m3/h you will als need a noise suppression system in the air intake. Normally this are sheetmetal fabrications with many punched holes in the sheet metal and a filling of Glas fiber mats. Sorry I have no longer any info on producers of such kind of a system for Diesel engines but there is a link http://www.guh-schallschutz.de/de/schallschutz/produkte/schalldaempfer/lueftungsschalldaempfer.php?thisID=252 which shows large systems of such kind of noise suppressors. But the standard round mufflers (upper part of the web side) can be used too if you find the sufficient diameter for the motor's requirements.
In my case (20years ago) you had to wear "Micky Mouse ears" inside the engine room. But on the outside of the air intake noise suppressor there where measured 56 dbA in 1m distance - but you could see the running 650 kVA engine through the air intake noise suppressor! We did not have special means inside the engine room besides a heavy noise suppressing door - there were bare concrete walls only.
Do not forget bird protection nets and rain blocker or a 90deg down ward hood and design the air intake that way that the air speed at the required air volume is below 3m/sec other wise objects might be taken into the engine room.
08/17/2011 6:16 AM
The best products, that I have used, are made by Soundown who produce a wide variety of sound attenuation materials and acoustic isolators and dampers. (http://www.soundown.com/Section%201%20PDFs/Products.pdf) With their laminated barriers, vibration damping mounts, well designed muffler, and properly baffled air intake and ventilation ports you will be able to reduce noise to whatever level is required.
To an optimist the glass is half full, to a pessimist it is half empty, but the engineer knows that the glass is twice as large as it needs to be.
08/17/2011 8:46 AM
Get another geneator frst.
Register to Reply 9 comments
Anonymous Hero (1); dbash (1); johnnyroy (1); lyn (1); ozzb (1); PWSlack (1); Rorschach (1); TonyS (1); uli_newBuilder (1)
