Previous in Forum: Metal Inclosure To Plastic Conduit   Next in Forum: UL Certifications for Luminaries
Good Answers: 170
AC Cable for use in DC
08/24/2011 8:45 PM
1.1 KV rated LT cable can be used for how much DC voltage (continuous duty) ? any impirical relation or ref. book you can suggest?
Good Answers: 150
Re: AC Cable for use in DC
08/24/2011 9:11 PM
1.1KV obviously. the limitation will be the breakdown voltage of the insulation which is pretty much agnostic towards the direction of the current. (the exception being high frequencies where it does matter.).
Who is John Galt?
Good Answers: 11
08/24/2011 9:28 PM
Contact the cable manufacture.
The DC rating should be higher than the peak AC rating, but it could also be lower in some cases.
India - Member - New Member
Good Answers: 164
08/25/2011 1:31 AM
Though this Wiki extract refers to HVDC, it should be even more valid for 1.1kV ?
HVDC can carry more power per conductor because, for a given power rating, the constant voltage in a DC line is the same as the peak voltage in an AC line. The power delivered in an AC system is defined by the root mean square (RMS) of an AC voltage, but RMS is only about 71% of the peak voltage. The peak voltage of AC determines the actual insulation thickness and conductor spacing. Because DC operates at a constant maximum voltage, this allows existing transmission line corridors with equally sized conductors and insulation to carry more power into an area of high power consumption than AC, which can lower costs
Good Answers: 181
08/25/2011 2:02 AM
The one time I could see this causing a problem is if you used 1100V + or - to a grounded 0V. The voltage to earth may be too high.
Register to Reply 4 comments
Carl Pugh (1); kvsridhar (1); Rorschach (1); TonyS (1)
