Previous in Forum: Using Non Conventional Energy Sources   Next in Forum: Paint Strip Chemical Fume Extractor
10 comments
An Unlimited Energy Source?
08/25/2011 12:47 PM
Hopefully, after I re-title this post properly, it will appear properly on front page first.---
If we are willing to spend tens of billion on research on Tocomak for fusion energy, why don't we do research on vertical tunneling to the Earth upper mantle layer for geothermal power ? The amount of energy is also limitless. It is only about 30~50 km deep. There are many countries in the ring of fire where the upper mantle layer should be even shallower. Today's technology already enable tunneling over hundreds of km, what is so difficult about just tunneling in a different direction? I imagine all we need to do is to ask the driver of the tunneling machine to steer downwards and make sure he keep going straight down, after a few months or years, he will reach the giant fire box, then he spray water on it, collect the steam to the steam turbine generator. The exhausted steam will rise up the tunnel, as it rises up, it cools and condense and flow back down to the fire box and the cycle can repeat endlessly without needing an extra drop of water and endless energy flow out ! Wouldn't that be nice and cheaper !
Silly/light-hearted and serious discussion are welcome !
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: An Unlimited Energy Source?
08/25/2011 10:15 PM
Geothermal is no doubt a large energy source, but it is not unlimited, nor truly renewable.
08/26/2011 5:00 PM
For all practical purposes , it is unlimited, it is as good as renewable.
08/27/2011 9:49 AM
"For all practical purposes , it is unlimited..."
Isn't this what was said about oil... only thirty years ago?
08/26/2011 11:59 AM
Are you under the misunderstanding that this has not been thought of?
Have you watched the news about the geothermal sites that are in operation and the problems involved?
08/26/2011 4:58 PM
You could share with us what you have learned.
08/29/2011 2:14 PM
Just use search and follow energy blogs that you may trust to some extent.
Over a period time you get the overall picture without the blather that the pros & cons throw out.
Good Answers: 59
08/26/2011 4:59 PM
Geothermal was discussed at length, width and depth some 1 year ago right here. The example was the Yellowstone National Park hot magma drilled into from the outside. The other example was Iceland's actual geothermal power.
The problems were mainly the unobtanium1 for drilling into high temperature magma. The other one was the unobtanium2 for withstanding the agressive water in piping. The next one from the top of my head was the mineral laden discharge water. The last one I recall was the likely trigger of earthquakes. Minor things, like multigigawatts steam released from cooling towers, altering the local climate and such does not even merit mentioning. Oh, and yes, the Icelandic EXPERIENCE.
What are they worth, in face of somebody dreaming (or smoking something)?!?
Good Answers: 44
08/29/2011 1:21 PM
There is always geothermal research happening in Washington State. The state has converted several restroom facilities for the parks department over to geothermal, but the use is very limited.
Here is some reference: http://northofthehotzone.com/
08/31/2011 4:01 AM
New Zealand. Iceland......
09/30/2011 4:12 AM
Thanks for such useful information
Register to Reply 10 comments
bravo88 (2); cuba_pete (1); Doorman (1); Egan (1); leveles (1); PWSlack (1); russ123 (2); Tornado (1)
