Previous in Forum: Help Needed Balancing 3-Phase House System   Next in Forum: Power Transformer Taps
Locked Rotor Current
09/01/2011 1:30 AM
what is locked rotor current...??/ i searched in internet but i couldnt get the excat explanation....
do LRC is the current which the motor draws during starting of teh motor or draws when rotor gets jammed...????
Re: locked rotor current...???
09/01/2011 1:46 AM
These two situations are nearly synonymous. Until the rotor of a starting motor builds some speed, it is virtually the same as a stalled/locked/jammed rotor.
09/01/2011 3:55 AM
The Locked Rotor Current is the supply voltage divided by the terminal resistance.
09/01/2011 11:53 PM
If rooter is "Locked" and motor is powered up the drawn current called Locker Rooter current which is 6-8times > the full load current.
Good Answers: 244
Re: Locked Rotor Current
09/02/2011 5:52 PM
Register to Reply 4 comments
msamad (1); PWSlack (1); Signode (1); Tornado (1)
