Previous in Forum: The High Visibility Epidemic   Next in Forum: Inspiration Needed...
Electricity From Nuclear Waste
09/01/2011 10:51 AM
I remember reading about a process to produce electricity from spent nuclear fuel rods.
The rods were place inside of a copper coil, and the neutrons striking the copper wire detached electrons and created current flow.An oscillator was required to sustain and convert the electricity to a usable voltage and current.
I am sure the power density was too low for large scale generation, but could be used in small scale community generation facilities.The article spoke of a garbage-can size unit powering a home for hundreds of years.It was to be embedded in a bore hole with alternating layers of lead and concrete for safety.
Sounded like a good idea( a little too good?) unless you live in a fault zone.
Anyone else hear of this?
Good Answers: 150
Re: Electricity From Nuclear Waste
09/01/2011 2:18 PM
A more efficient system is a SNAP generator (RTG), but their output is pretty low (but steady!) they surround the decaying radioisotope with an array of thermocouples and use the temperature differential between the isotope's decay heat with the surrounding environment (which in space is damned cold!) to generate power. But they only develop a few hundred watts of power generally. They have been used to power pipeline SCADA systems in remote areas here in the US and to power lighthouses in the former USSR. There has been talk of using them subsea to power subsea oil and gas wellhead telemetry systems as well. (it gets pretty cold down there too and there isn't a lot of people wandering by to be irradiated either.) I think Russia had the most powerful design ever built and it produced around 1200W if memory serves but the beast was dang near 10 ft tall. it was proposed to power Cassini but NASA ended up going with a different design. I think only one prototype was ever built.
Who is John Galt?
09/01/2011 11:46 PM
Haven't heard of this, but have heard about the IFR (Integral Fast Reactor) that can use the current "waste" as fuel to generate electrical power. The waste it produces is much less and much less radioactive. I'd like to learn more about it.
Lehman57
Register to Reply 2 comments
