In our vessel there is continuous flow of yellow tint color in the accommodation Hot water system. We inspected and clean the calorifier but condition of the water remains the same. Vessel has also cleaned Fresh water tanks. Fresh water lines Do not have this problem, it is only hot water which is getting rusty color and remains so even after draining the lines and calorifier thoroughly.
We suspect there is indifferent use of metal in the system which is causing galvanic corrosion in the pipe line at much faster rate.Calorifier is SUS 304 stainless steel and piping copper and Galvernized steel. What section of the lines are more likely to cause this effect? Temperature of the water is kept between 45 - 50 deg. Centigrade. Also found iron particles in tested water sample.Kindly advise any preventive action.
