Previous in Forum: Low Melting/Vaporizing Cast Material?   Next in Forum: Pin Holes and Blow Holes
Protect Wooden Table From Scratches
09/06/2011 6:27 PM
I install my new kitchen, and a mini bar table is made of poplar wood, with red stain and cover with polyurethane, but since the first time I place something over it I saw it leaves some small scratches, so before it gets worse, what's recommend to protect it from scratches, without affecting the color?
Pathfinder Tags: scratches wood
Good Answers: 88
Re: Protect wooden table from scratches
09/06/2011 6:30 PM
Tempered glass. S.M.
Good Answers: 146
09/06/2011 11:03 PM
Poplar is a fairly soft wood. I agree, a slab of glass is the best if not the the only way to protect it from scratches in the long term.
incus opella
Re: Protect Wooden Table From Scratches
09/06/2011 8:38 PM
What was the particular polyurethane coating you used (brand name and product); perhaps the coating wasn't hard enough? How many coats did you apply? Did you sand between coatings?
For some things I would use a tempered glass top as SM suggests - it would definitely do the job, but for a bar table, I might want a more natural look.
Good Answers: 74
09/06/2011 10:09 PM
Cover the scratch causing culprit with felt or anything that is not scratchy.
Or make it float on magnets.
The Twain Has Met
09/06/2011 10:18 PM
Buff the bottoms of beverage containers, thereby removing whatever sharp projections that could scratch the table. (?)
09/07/2011 5:55 AM
You could have used this, but it's not compatible with the existing polyurethane.
Since the polyurethane is already in place, just wax and buff it occasionally.
Register to Reply 6 comments
artsmith (1); kramarat (1); ky (1); Mikerho (1); SimpleMind (1); Tornado (1)
