Previous in Forum: Throw of Air on a Split Type Aircondition   Next in Forum: Pressure Vessel Factory Inspection
25 comments
Pressure Test
09/07/2011 2:48 AM
I want to make a test for a suction lines for a complex vertical pumps (3 lines with 8 " diameters ) and Have 19 joints ( flanged with valves ) ,,,
I will pressure the line about 15 Bar for 8 hours
after 7 hours the pressure gauge read 13.7 bar
and there was a leakage ,,, i had an equation
L=ND(P)^0.5
where :
L= Allowable leakage (gal per hour)
N= No. of Joints in tested line (pipe and fittings)
P= Average test pressure (psi)
D= Nominal diameter of pipe (inches)
Is there standard test ?? (ASME or ASTM or DIN or BS ) to check about this equation ???
Is (1.3 bar ) allowable to be reduced ?????
Re: Pressure Test
09/07/2011 3:01 AM
The formula L = NDP0.5 is somewhat rational, except that it lacks a constant for units conversion/consistency. If I wanted to be really sticky-wicket, I would set this constant (call it K) to zero. But what the hey, we can entertain other numbers..., depending on how toxic/corrosive/valuable the fluid is.
Re: Pressure Test
09/07/2011 3:06 AM
the fluid is WATER
And really i do not know if the test will pass or not with this reducing at pressure
my group had tighten all bolts as they can
Re: Pressure Test
09/07/2011 3:30 AM
Try it and see?
Re: Pressure Test
09/07/2011 4:35 AM
What are the criteria that determine whether the test is a pass or a fail?
Re: Pressure Test
09/07/2011 5:23 AM
that the test of pressure stay at value of 15 bar or may be less ?? but the range i do not know it ??? means does 13.7 bar is approved or not ?
Good Answers: 34
Re: Pressure Test
09/07/2011 3:52 AM
1.- Did you see the leakage?
2.- Flanged valves could be checked? (it is possible to blind limit points?
3.- Wich was the change of temperature during the holding 8 hours?
4.- The 1,3 bars pressure decreasse is to much.
Re: Pressure Test
09/07/2011 4:25 AM
i was drops of water
and i had checked flanged all
temperature is a constant cause we are at pump room
do you know the equation of leakage
Good Answers: 34
Re: Pressure Test
09/07/2011 5:03 AM
No sure, but may be MSS-SP-126- 200 can help.
Re: Pressure Test
09/07/2011 5:24 AM
what is that code ??
do you have a copy of it ?
Good Answers: 34
Re: Pressure Test
09/07/2011 5:47 AM
"The maximun allowed leakeage rate on each seat of metal-seated valves for the duration of the test shall be 4/10 of the standard cubic foot of gas per hour per inch of nominal valve size, or a maximún of 2.44 cubic inches of hidrostatic test media per hour per inch valve size at the test pressure spicified"
Send me one E mail to give you a copy of this MSS-SP- 110
Regards, WP
Re: Pressure Test
09/07/2011 6:40 AM
my email is
and really thank you so much for your support
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 34
Re: Pressure Test
09/07/2011 8:58 AM
OK, not possible, try to find Mss-SP-100, and go to point 7.
May be this way: joecollet88 ya oo. c-m
Good Answers: 70
Re: Pressure Test
09/07/2011 8:52 PM
You guys can send each other personal messages by clicking on each other's name and use the CR4 personal messaging to email each other. It works great!
Re: Pressure Test
09/08/2011 3:52 AM
thank you
we did it ;)
Good Answers: 34
Re: Pressure Test
09/08/2011 3:52 AM
Thanks
Re: Pressure Test
09/07/2011 8:05 AM
Re: Pressure Test
09/07/2011 4:30 AM
The acceptable leakage rate is determined by the fluid and the local environment. If the working fluid were water at ambient supplied to water a garden, then the leak rate might be acceptable as it wouldn't matter too much. If the fluid were, oh, say a solution of a plutonium nitrate within a nuclear power station, then no leakage would be tolerable.
So there is insufficient information to make a recommendation in this case.
Re: Pressure Test
09/07/2011 5:26 AM
agree with you
but the floor will be wet and that not acceptable ,,
may be if a liter per hour will be acceptable but 8 liters is not ?? right ?
Re: Pressure Test
09/07/2011 8:35 AM
The acceptable leakage rate is still determined by the fluid and the local environment. The latter cannot be seen from here.
Re: Pressure Test
09/07/2011 8:45 AM
ok
thank you for your information
Re: Pressure Test
09/08/2011 9:10 AM
In new piping systems used in oil & gas and designed as per ASME code, no leakage is permitted, the only leakage accepted is in testing of valves as per API. And with test pressure 13.7 bar, the test is considered not passed unless it reach 15 bar as specified by the designer.
So, you are kindly requested to re-tight the stud bolts of flanged connections (as per the recommended procedure) until you reach the specified test pressure without any leakage, and may be you need to use a new gaskets.
Re: Pressure Test
09/08/2011 3:49 PM
dear engr. Abdel halim
Really your massage makes me happy that i found an egyptian here
and i had re-test the pipe after changing the gasket
and take approved :)
Re: Pressure Test
09/09/2011 1:01 AM
Thank you stylee_eng for your compliment.
It is a good sound to hear that you changed the gaskets and retest was passed.
Note. There are a lot of Egyptians here as members of CR4, and I invite yours for registration, see this link: http://cr4.globalspec.com/group/members/5/Egypt.
Good Answers: 179
Re: Pressure Test
09/08/2011 4:30 PM
The "Allowable Leakage" equation that you're using is covered under:
ANSI/AWWA C600-10, AWWA Standard for Installation of Ductile-Iron Mains and Their Appurtenances
(Revision of ANSI/AWWA C600-05). Hydrostatic testing procedures are specifically covered in Section 5.0 of the standard.
You can purchase a copy of the standard at the American Water Works Association (AWWA) website:
www.awwa.org
Also, visit the Ductile Iron Producers Research Association (DIPRA) website for additional information:
www.dipra.org
NOTE: Please bear in mind that you can also take a "leakage allowance" for each closed valve you at hydrostatically testing against.
Re: Pressure Test
09/08/2011 10:51 PM
many thanks for your support
Register to Reply 25 comments
Abdel Halim Galala (2); CaptMoosie (1); dj95401 (1); PWSlack (3); stylee_eng (11); Tornado (2); Whitephone (5)
