The situation:
I service a shredder that feeds a pulper. It shreds debris and feeds the slurry to a pump located aprox. 8 feet away. The drive motor is 3 phase, 208V. The shredder and pump use the same supply source from a 30 amp breaker mounted in the control panel. When the shredder rotation is correct, it feeds the pump. When rotation is incorrect the pump is starved and and it loses suction.
The problem:
The shredder has "magically" reversed rotation twice in the past month. However the pump has not. I noted that the shredder was not running in the correct rotation (pump was correct) and switched two leads to correct the rotation. But rotation did not change. It would not be the first time that I became distracted and put the leads back in the same placement. So I swapped them again and the shredder rotation was correct.
Is there any way that the motor can "magically" change rotation without changing lead positions ? Or not reverse when lead positions are changed? The unit is a couple of months old. I am thinking of switching contactors between the shredder and pump just to see if the pump magically reverses rotation, a good place to start I figure. As far as I can determine no in house maintenance folk have even opened the control panel. Any input would be appreciated and more information can be provided if requested.
I Thank you all in advance.
