Previous in Forum: Surface diffusion and desorption activation energies   Next in Forum: Does Laser Cutting Harden Mild Steel?
Pressure Exerted By the Biogas From BIodigester
09/09/2011 3:04 AM
Hi All,
Could you please let me know your suggestion on below questions.
what is the pressure exerted by the Biogas from BIodigester?. what is the miniumum and maximum pressure can be handled by LPG burners?
Thanks,
Siva
Re: pressure exerted by the Biogas from BIodigester
09/09/2011 3:55 AM
The answer to the first question is "usually a couple of inches water gauge". At a big municipal works, the digester gas is usually stored in a "gas bag", which is quite a flimsy structure. Higher pressures would split it.
09/09/2011 7:51 AM
Hi,
Could you please let me know how can we calculate?. Give me an example
thanks
09/09/2011 10:41 AM
Calculate? Why not stick a manometer on it instead?
Good Answers: 67
09/09/2011 5:03 AM
Pressure exerted by the Biogas from Bio-digester is very low as commented at#1. LPG burners can handle what ever pressure you produce. Flame will be higher at more pressure. Your supplier may also be able to tell you this information. Pressure you can measure with water tube manometer by connecting the water filled transparent tube at suitable tapping, but that tapping should be always closed except at the time of measurement.
Register to Reply 4 comments
DDR (1); pritam (1); PWSlack (2)
