Previous in Forum: What Is d Work of Electrical Motor Design Engineer   Next in Forum: Failure of Lightning Arrestors
10 comments
Direction of Fan
09/12/2011 1:02 AM
Table fan and ceiling fan rotates in opposite direction-why?
Is it true ?
Good Answers: 141
Re: Direction of Fan
09/12/2011 2:16 AM
Not necessarely.
A table fan must run according the pitch of the blades, must "spoon" the air.
A ceiling fan mostly has a reverse switch and can run both ways.
Plenty of room here
Good Answers: 804
09/12/2011 2:31 AM
I have two table fans that run in opposite directions. It means absolutely nothing.
Fans either suck or blow. The direction of rotation is relevant only to the blade pitch and the suck or blow decision.
Good Answers: 12
09/12/2011 2:38 AM
I think there is no hard and fast rule. It depends on blade design.
Subramanyam
09/12/2011 2:46 AM
if your fan is single-phase then it must be the blades that are interchanged..
take care of your seconds and the minute will take care of itself..
09/12/2011 6:55 AM
Doesn't it depend upon the direction the fan is viewed from?
09/12/2011 8:03 AM
In a general sense, yes. But the rotation of the fan blades with respect to the air flow can be either left handed or right handed.
(I bet you knew that.)
09/12/2011 9:23 AM
Good Answers: 58
09/12/2011 8:56 AM
One fan was purchased in the southern hemisphere, the other in the northern hemisphere.
Mystery solved
09/12/2011 9:12 AM
I love your comment - Thanks
Good Answers: 44
09/12/2011 11:44 AM
This would depend on which end of the motor that the drive shaft was fixed to. I never really compared them before, but it is interesting.
I don't buy that it depends on the fan blades per se, I would say that the fan blades and motor were designed to the desires of the person who makes it and puts it all together. Someone somewhere made the conscious decision to say that the fan would rotate clockwise/counter clockwise.
Also, if you look at the fan blade from a physicist's perspective the blade is not "scooping" the air. The curve of the blade creates a positive pressure zone on the forward facing blade and a negative pressure zone on the obverse, thus creating the breeze.
A sailboat is not pushed by the wind, but is pulled forward into the negative pressure area created by the sail. A wing does not "lift" an aircraft, it is pulled into the negative pressure created by the wings shape (which is not flat in any direction).
Register to Reply 10 comments
cuba_pete (1); dvmdsc (1); JRaef (1); KJK/USA (1); kvsubramanyam (1); PWSlack (2); rockraiden (1); Sakthitharan (1); Usbport (1)
