Previous in Forum: 2000 Cavalier 2.2   Next in Forum: 2 Stroke vs 4 Stroke Engines
84 comments
Proprietary CVT Fluid
09/17/2011 6:39 AM
Hi, my daughter has a 07 Altima with a CVT. Trying to do the right thing, she did a drain and refill at 60k at a chain. They used an NS 2 fluid, but not the proprietary fluid from Nissan. The tranny went and now the parties are pointing the finger at each other. The color of the fluid used to replace the old is red and the Nissan fluid is green, so they knew it wasn't theirs. Nissan says it is the fluid's fault and voided the warranty. Jiffy Lube says their fluid has all the specs of the Nissan fluid and won't pay. QM1 says their fluid is the same chemically as the Nissan fluid. Jiffy Lube gave a sample to an independent lab and they said the fluid is the same. The car had 1700 miles on it after the drain and refill when it began to go. Most of it was highway. a) is this enough to wreck the tranny? b) who should pay? (my daughter even bought the extra warranty) c) is there much trouble with these?
Pathfinder Tags: CVT
Re: Proprietary CVT fluid
09/17/2011 2:18 PM
You need legal advice, not engineering advice.
A friend of mine had similar problems he had with a pickup truck with the dealership of a different foreign (to the US) vehicle manufacturer. He had the truck towed and legally parked in front of the dealership with a big sign in the back saying "This dealership does not honor warranties!" or something to that effect. This generated a different tempest of bad feelings that reached the local news services. The parent company then some how heard about the battle and stepped in. The truck was repaired at a different dealership (not for free but my friend was both satisfied and unwilling to explain). Within a year the recalcitrant dealership lost their franchise from that manufacturer. This whole saga took close to a year.
I hope that you don't have to go through this much of a nightmare but it can and has happened.
09/17/2011 4:17 PM
My sister resolved a warranty issue (requiring a replacement engine) only after contacting the California Bureau of Automotive Repair.
I imagine there are similar resources in other states. Other countries...?
09/17/2011 4:50 PM
You can put in any tranny fluid you want, it won't have any different 'specs' than any others. tranny fluid is tranny fluid, no matter what brand. I would take from what bob c said, and do something about it. They just want to rip you off, and make you think it was your fault for it.
Plus if it is chemically tested to be exactly the same, then it was definitely not because of that. If I were you, I'd do what the guy in bob c's story did. But warn them first, so they have a chance to change their mind, and just follow through with the warranty. Give them their 2 options:
1. Follow through with the warranty, and you will only spread good news about them.
or
2. You stand outside their lot, and tell people going in to look at the cars about what happened to you until the tranny is fixed.
Good luck! :)
09/18/2011 6:44 AM
You seem to be out of place here. "tranny fluid is tranny fluid" is hardly sound advice. Especially coming from you. 1991 Camaro Transmission Problem
Now I've done it.
CR4 ADMIN: Edited Post
Abuse/Attack: This post was edited because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
Good Answers: 46
09/18/2011 7:32 AM
Now Lyn, ya know some people just are not car people.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
09/18/2011 10:44 AM
I've been fairly good recently and I re-wrote it twice to tone it down.
I believe that it is better to be quiet and let people think you are uninformed than to type away without a clue and remove all doubt.
Good Answers: 46
09/19/2011 1:41 AM
09/20/2011 2:33 PM
There is no reason to be so judge-mental.
If you don't like my advice, then ignore it. I was just trying to help.. Because, really, what is the difference between tranny fluids? THEY ALL DO THE SAME THING, and people like you don't understand that, because all you're good at doing is reading labels and forum posts. No offense.
09/20/2011 2:37 PM
No offense taken. But you are still wrong.
09/20/2011 2:52 PM
Ask your local mechanic, and prove yourself wrong.
Location: Ground Zero of the Pompous and self important....Washington DC
09/20/2011 3:07 PM
Why don't you?.....its clear you haven't yet. And a Flunky at Jiffylube...isn't a real Mechanic.
09/20/2011 3:19 PM
Because my car is running on a mix of 2 tranny fluids, some of what the car was sold to me with, and some meant for a Plymouth voyager. It still runs exactly the same, and It's gone through over 5,000 miles with that so far. (2001 Saturn coupe 3dr sc1). Plus when I changed the oil, I used different oil than what is intended for it. The car runs probably exactly the same as it did 10 years ago.
09/20/2011 3:38 PM
Gee, only 5,000 miles and that proves what? I feel sorry for whoever buys a used car you once owned.
09/21/2011 10:50 AM
Did you even read the original question here? his daughters nissan transmission broke after only 1700 miles of the fluid change, my car has run almost triple that much, with no problems. Plus I mistreat mine.
The only reason the fluid would have destroyed the transmission is if they accidentally put manual transmission fluid in, or didn't put enough fluid in. Unless if there is a leak.
Or it is possible that they didn't clean the pan before putting it back up.
Basically, as long as they used automatic transmission fluid, the car wouldn't have had any problems. ESPECIALLY that early.
09/21/2011 11:07 AM
Dude,
You should take up comedy, or is it fantasy?
No offense. Keep those pearls of wisdom coming.
CR4 ADMIN:Edited Post
09/21/2011 11:19 AM
You don't understand the fundamental flaw of an anecdotal argument, too.
09/21/2011 1:29 PM
Kevin, Are YOU even bothering to read ANYTHING everyone else here is telling you? Obviously not.
The wrong fluid WILL kill a transmission, guaranteed, every time. Period. It might be in only miles...it might be months...but it WILL lead to a premature death every time. NO exceptions.
How old are you anyway...and exactly WHAT experience do you have with vehicles....beyond putting fuel in the tank that is? I've seen 12 year olds with far better understanding of things mechanical. and I was one of those 12 year olds 38 years ago. I restore antique Mercedes Benz's as a hobby. I own and drive six antique vehicles now including 3 antique motorcycles. I do ALL my own mechanical work. I only farm out machining.
You make outrageous claims....say everyone is wrong but you, yet you provide nothing at all in the way of evidence to back up your claims that its all a racket and everything is really all the same.
And I wouldn't let Jiffylube touch someone elses car much less my own. I've personally known too many people who have had engines and transmissions killed by mistakes such as forgetting to put the plug back in to putting the wrong fluids in it.
I could do more when I was 12 than the average Jiffylube tech can do.
09/22/2011 10:44 AM
1. Your post is just you bragging about how 'great' you are.
and 2. You haven't proven anything either.
09/22/2011 11:13 AM
I've already proven you are likely a 16 year old that knows absolutely nothing aabout cars.
And I have also proven I forgot more about them last night than you have ever known.
Kowing where the gas tank is and where to find the spare tire doesn't make you an expert on cars. Or an autority to declare all transmissions fluids are essentually the same like you have claimed in this thread.
I've shown I have a LOT of background with cars to back my statements up.....you haven't proven you know how to change a flat tire yet.
09/22/2011 7:43 PM
No you did not.
No you did not.
I didn't say that, and they are all similar enough not to destroy your car. I've proven more than you, I actually tested my theory. The test is still in progress, but it's already gone a little over 5k miles without any performance differences, or anything.
Honestly, I think that most of what you told me is both irrelevant to the topic, and probably bull.
09/22/2011 9:01 PM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
09/22/2011 9:14 PM
1. You haven't proven ANYTHING, not even whether YOU can change a tire, find the dipstick, or anything more than putting gas in the tank.
2. Different types of transmission fluid do enough of the same thing to work alternatively together. The only problem with using the wrong fluid is that you would have to change it sooner than when you normally would with what is intended to be used with your car.
3. I wouldn't say something if it wasn't true.
4. Sloopster3 is probably annoyed with checking his email every 10 minutes.
Irrelevant This post was edited because it is related to a deleted post and would otherwise be taken out of context.
09/22/2011 9:23 PM
Gee, argue like a 14 year old too.....make all sorts of claims but isn't man enough to back up a single one with a shred of facts. And based on wheels falling off your car....you can't maintain what you have very well either.
34 years of driving nearly 2 million miles so far, and 14 different cars on two continents and 8 countries , I never had a wheel fall off yet. Or even get loose for that matter.
Everyone is laughing at you at this point.
In reply to #59
09/22/2011 9:42 PM
Please, read everything you've said in this whole forum, and tell me what you've proved.
It's IMPOSSIBLE to prove anything about yourself over the internet. Every thing that you've said to me sounds like bull, but I'm mature enough not to sit here and guess who you 'really are,' and what it is that you 'really do' for a living.
The wheel fell off on my way home with it WHEN I BOUGHT IT. It was not at all my fault, and it was no big deal. The lug nuts were either loose, or not even there. I bought it to be a project car, and that's what I got. A $600 car.
09/22/2011 10:03 PM
In reply to #65
09/22/2011 10:12 PM
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
In reply to #67
09/22/2011 10:17 PM
In reply to #69
09/22/2011 10:19 PM
In reply to #70
09/22/2011 10:25 PM
I don't have to.....Everyone who knows anything at all about cars KNOWS you use the correct type of fluid for the vehicle.....and ONLY what the manufacturer specifies. THere are extensive specifications for required fluids. THe engineers that designed them KNOW what they were doing.
I've been doing this 38 years. There isn't something on a car I haven't rebuilt yet.
You on the other hand claim they are all the same and there are no differences, and its a racket. YOU prove the industry is wrong and prove your claim. The only reason you don't is because you can't.
So.....prove it. You have shown NOTHING yet to back up any of your claims. I'm waiting....my proof is in the fluid specs themselves, and the vehicle Factory service manuals.
In reply to #71
09/22/2011 10:34 PM
I've really done all I can to prove it to you through the internet. Especially being that you are obviously a very stubborn person.
In reply to #72
09/22/2011 10:40 PM
I've read every single post in this thread....you have presented NO proof, you have presented NO links to prove anything.
So since you can only edit 15 minutes before a post locks. point out by post number in this thread where you have done ANYTHING to prove anything you have claimed in this thread yet.....
That would be easy to do if you actually did what you just claimed to do.
I see a lot of talk....and absolutely nothing else from you, so what are the post numbers in THIS thread where you have made these world altering proof?
In reply to #73
09/22/2011 10:55 PM
Get over yourself, you lack variety. What is your point in continuing this argument anyways? I never told you to put the wrong fluids in on purpose. (Except when I told you to get a really cheap car, and test it yourself).
If using the wrong transmission fluid in your car wrecks it, neither of my cars would be running right now. -That's the best proof I can really give you..
In reply to #74
09/23/2011 7:30 AM
Hey, YOU made the claim that transmission fluids are all basicly the same and interchangible, and that selling different types are a racket.
Engineers, something you are clearly NOT say otherwise.
YOU need to back up the claims you make. YOU claimed you already proved in in this thread they were basically the same....I said provide the post number or numbers where you have. If you in fact have, that would be easy for you to do since I can't find a single instance you have backed up your claims.
Instead you make remarks offensive to those of us who actullay have attended college and acquired an Engineering degree in some discipline.
09/22/2011 11:26 AM
You originally came here for advice on your vehicle transmission. At that time, you admitted that you knew nothing about transmissions (and probably cars in general) but said that you had friends who did. You rememberdon't you? Your wheel fell off and then your tranny dodn't work. Brilliant!
Then, a week later, you are giving advice like you are a seasoned mechanic. (Advice which is clearly wrong) And what's worse is that you refuse to listen to people who have been on the forum for far longer than you have and who OBVIOUSLY KNOW TONS MORE ABOUT CARS THAN YOU EVER WILL!!!!
I, for one, will not ever respond to you again.
Goodbye!
09/22/2011 7:28 PM
I'm not sure if I said NOTHING, but I'll re-admit that I don't know much about them. I've fixed a leak on one, and changed the fluid 4 times. (different car each time). So obviously I know a few things about them, just forgot I unbolted the linkage on mine so I looked it up and found this website.
I was giving advice based on what I know, what I've learned, and what I've experienced. You, on the other hand, have only jumped to conclusions. You don't think the wrong transmission fluid would work, because nobody does it, and you go by what the book says to do.
It's probably better that way, you don't seem to get along with other people too well.
Farewell.
09/22/2011 9:08 PM
09/22/2011 9:19 PM
09/22/2011 9:24 PM
In reply to #60
09/22/2011 9:48 PM
09/22/2011 9:56 PM
Good Answers: 123
09/22/2011 12:33 PM
Hey, how is the transmission linkage on your Camaro?
Bob
09/22/2011 7:55 PM
I bolted the linkage back up to where it should be, but I'm not sure yet whether that was the only problem. I want to get the exhaust on before I start it up again, and take it for a test drive. The neighbors don't like how loud it is lol. Being that it's dual exhaust, and such a huge engine, It even hurts my ears while it's running!
The guy I bought it from was putting cherry bomb mufflers on. He only had one side on when I bought it, but I had to take that down.. It was not hanging right AT ALL. He was re-doing the whole exhaust, so instead of being more of an X shape, like it's supposed to be on these cars, he was setting it up to be 2 straight pipes all the way.
Thanks for asking!
09/20/2011 2:40 PM
No, not all transmission fluids are the same. They don't all do the same thing. The most extreme difference is the relatively sticky 90W gear oil of a 50's era manual transmission and today's highly slick but self coating fluid of a modern automatic transmission with a lock up torque converter.
09/20/2011 11:53 AM
I'm with Lyn on this.......tranny fluids are NOT all the same by a long shot.
Would you go to the Pharmacist and tell him just give you anything....they are really all the same anyway. Drugs are drugs after all.
No you wouldn't.......and while I'm at it...it applies to oil, antifreeze, brake fluid, power steering fluid and just about everything else.
09/20/2011 2:46 PM
Ok, let me put your example a different way.
you have a headache, so you go get medicine for that. There are different brands that some use a few different ingredients to take care of the headache with, right? Well of course you're going to get the stuff that you think would fit best with your headache. Although, each of them would have done the same thing, you chose that certain one. They would have all done the same thing -- like the fluids in your car. If you want transmission fluid for your 2007 Nissan, it would probably be best to use what is made specifically for it, but still.. any other transmission fluid would have done the same thing.
And this does apply with oil, brake fluid, and power steering. Maybe antifreeze too, but I don't really know much about that.
09/20/2011 3:01 PM
We're not talking about the marketing brand differences between a Mobil, Castrol or Valvoline version of ATF or Dextron transmission fluid. We're talking about the difference between ATF, Mercon, SP-III and Dextron. These difference can affect seal integrity, the amount of fluid that reaches different crevices, the amount and size of debris that will be suspended and how hydrophobic the fluid will be.
09/20/2011 3:05 PM
No....you aren't getting it kevin12340. They are drastically different. Not simply having slightly different additives. To the point using the wrong one in the wrong transmission WILL most certainly cause a failure, not maybe, not possibly, but most definately. Its not at all like compairing headache medicine.
You don't run 0W40 in a '69 corvette, you don't put 20W50 in a Rolls Royce Turbine. You don't put oil for gasolene engines in a diesel engine.
Put the wrong brake fluid type in your car and you will find yourself without brakes. Put the wrong antifreeze in the car you will find yourself walking.
No it HAS to be the right type.....any other transmission fluid type will NOT do the job.
Types are not brands.
But you can continue to believe as you wish.....Transmission shops can use the extra work. Just don't blame anyone else when the transmission fails when you do it.
Word of advice......don't ever buy an older British car (or anything of any real value). Buy something disposible with no collector value.
09/21/2011 11:01 AM
You won't understand until you try it. Go buy yourself a $400 car, change all the fluids, put in the wrong fluid for each one, and tell me you're sorry for wasting my time on this thread.
Good Answers: 123
09/21/2011 11:25 AM
The vehicle in question, is not a $400 POS. it is his daughter's 2007 new car that was maintained "by the book" until this failure.
You could put dog crap into a manual transmission and drive 1700 miles. What are you trying to say here?
Do you think that a company like Valvoline (for example) wants to have to market 10 different transmission fluids? Each one is marketed because there is nothing else that is usable in certain applications. Synthetic ATF will work in a 91 Camaro with a 700R4, but there is a chance that the owner of that car will not want to pay the price for synthetic, so they must market Dextron for that owner, or chance loosing that lucrative market.
Bob
09/21/2011 11:52 AM
Well 1700 miles is pretty far, I don't think dog crap would last much longer than 5 miles. (10 if you're lucky, but I don't know where you'll get 4 - 5 quarts of dog crap anyways).
None of you are seeing my point, though. Of course it's BETTER to use what your car calls for, but using the wrong transmission fluid won't wreck your transmission, using regular oil after synthetic has already been used won't damage your engine, the wrong power steering fluid won't destroy your power steering, the wrong brake fluid won't stop your brakes from working. Antifreeze is the only fluid that I think you should put the right type in for.
09/21/2011 12:06 PM
NO! You are the one who refuses to see our point. CR4 is an engineering community. A shade tree mechanic's experience is nothing more than an anecdotal amusing story that proves nothing but that one can be lucky. You have no understanding of a sound, scientific mechanical or chemical analysis of any system.
You are wrong and embarrassing in your death grip on ignorance.
09/22/2011 10:37 AM
I could say the same thing to you, but it would probably come in simpler words.
Good Answers: 123
09/21/2011 2:58 PM
Now I see your point. Yes you can put any old fluid in your master cylinder. The old wife's tale about petroleum products swelling rubber brake products is just hog wash.
Bob
09/21/2011 1:45 PM
Well, You take a $400 car and turn it into scrap value. I on the other hand have been been riding a $50 motocycle I bought 20 years ago.....for the last 20 years. And I can sell it now pretty easily for $4,000-$5,000 Dollars. I on the other hand put the right fluids in it. Not the wrong ones. And I haven't done much more than one paint job, a few cable changes and brake relines, tuneups, and tire changes in all that time.
09/20/2011 6:31 PM
kevin, I get the feeling you are neither an engineer or a mechanic.
Ted
Good Answers: 123
09/21/2011 10:27 AM
Hey, that was not me in posts 1 and 2, it was Lyn. Just because we went to different schools together people always get us confused.
Bob
09/21/2011 10:35 AM
I'm better looking!
09/21/2011 10:39 AM
Modest too.
Good Answers: 123
09/21/2011 10:50 AM
Only if I shave my head, and walk on my hands.
Bob
09/21/2011 10:53 AM
Actually it was redfred, I didn't realize that haha. Oops!
Good Answers: 88
09/17/2011 5:10 PM
Obviously most don't seem to have a clue that CVT fluid is a very special characteristics fluid with VERY unlinear pressure/friction coefficient and is not replacable by ANY kind of common oils. But you still have a chance to win a legal battle if there were no specific warnings on manuals, and no special tools needed to drain and replace old fluid. S.M.
Good Answers: 46
Re: Proprietary CVT Fluid
09/18/2011 3:46 AM
After looking for info on NS2 fluid. On a Nissan auto site someone in a similar situation had had there fluid changed at a store not the dealer now there worried about void warranty.
Anyway there some law govern warranty that may give you some help with the dealer so long as you can get the service to provide that there fluid is in fact compatible to Nissan's brand.
I started with Google Magnuson and Moss warranty act.
On MLM Law.com down the page a little ways fount this:
""Tie-In Sales" Provisions
Generally, tie-in sales provisions are not allowed. Such a provision would require a purchaser of the warranted product to buy an item or service from a particular company to use with the warranted product in order to be eligible to receive a remedy under the warranty. The following are examples of prohibited tie-in sales provisions.
In order to keep your new Plenum Brand Vacuum Cleaner warranty in effect, you must use genuine Plenum Brand Filter Bags. Failure to have scheduled maintenance performed, at your expense, by the Great American Maintenance Company, Inc., voids this warranty.
While you cannot use a tie-in sales provision, your warranty need not cover use of replacement parts, repairs, or maintenance that is inappropriate for your product. The following is an example of a permissible provision that excludes coverage of such things.
While necessary maintenance or repairs on your AudioMundo Stereo System can be performed by any company, we recommend that you use only authorized AudioMundo dealers. Improper or incorrectly performed maintenance or repair voids this warranty.
Although tie-in sales provisions generally are not allowed, you can include such a provision in your warranty if you can demonstrate to the satisfaction of the FTC that your product will not work properly without a specified item or service. If you believe that this is the case, you should contact the warranty staff of the FTC's Bureau of Consumer Protection for information on how to apply for a waiver of the tie-in sales prohibition."
From my interpretation, (And I'm NO lawyer) The dealer has to prove the fluid was the problem not just because it was not theirs. They are required to service the trans if upon repair "it was the fluid" you could be charged then you would have to go after the oil change place for not using the proper fluid. Even if they gave you your money back they are still on the hook for causing the damage.
Follow the google link above you will see where I'm going with this...
Good luck on getting your car fix quickly.
Oh, find ALL your warranty paperwork too make sure there no fine print to the contrary.
Good Answers: 46
09/18/2011 4:42 AM
Oh additional site to get a better read on the Magnuson and Moss warranty act.
"The Magnuson-Moss Warranty Act states, in part, in Title 15, United States Code, Section 2302, subdivision (c):
No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer's using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the [Federal Trade] Commission if -
(1) the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and
(2) the Commission finds that such a waiver is in the public interest. The Commission shall identify in the Federal Register, and permit public comment on, all applications for waiver of the prohibition of this subsection, and shall publish in the Federal Register its disposition of any such application, including the reasons therefore.
Under this federal statute, a manufacturer who issues a warranty on your motor vehicle is prohibited from requiring you to use a service or maintenance item, unless such item is provided, free of charge, under your warranty or unless the Federal Trade Commission (FTC) waives this prohibition against the manufacturer."
"Specifically, the rules and regulations adopted by the FTC to govern the interpretation and enforcement of the Magnuson-Moss Warranty Act are set forth in the Code of Federal Regulations, Title 16 - Commercial Practices, Chapter I - Federal Trade Commission, Subchapter G - Rules, Regulations, Statements and Interpretations under the Magnuson-Moss Warranty Act, Part 700 - Interpretations under the Magnuson-Moss Warranty Act. Contained within these rules and regulations is Section 700.10, which states:
No warrantor may condition the continued validity of a warranty on the use of only authorized repair service and/or authorized replacement parts for non-warranty service and maintenance. For example, provisions such as, "This warranty is void if service is performed by anyone other than an authorized 'ABC' dealer and all replacement parts must be genuine 'ABC' parts," and the like, are prohibited where the service or parts are not covered by the warranty. These provisions violate the Act in two ways. First, they violate the section 102(c) ban against tying arrangements. Second, such provisions are deceptive under section 110 of the Act, because a warrantor cannot, as a matter of law, avoid liability under a written warranty where a defect is unrelated to the use by a consumer of "unauthorized" articles or service. This does not preclude a warrantor from expressly excluding liability for defects or damage caused by such "unauthorized" articles or service; nor does it preclude the warrantor from denying liability where the warrantor can demonstrate that the defect or damage was so caused."
"Under the Magnuson-Moss Act, a dealer must prove, not just vocalize, that aftermarket equipment caused the need for repairs before it can deny warranty coverage. If the dealer cannot prove such a claim - or it proffers a questionable explanation - it is your legal right to demand compliance with the warranty. The Federal Trade Commission administers the Magnuson-Moss Act and monitors compliance with warranty law."
Anyway the link talks about the "mod of a auto"
It still comes down to the dealer doing a tie-in with its "brand" of fluid, as only can be used to keep the warranty. Again my reading of the law (I'm no lawyer) if only there fluid will work they are to give it to you.
Now abc brand of fluid says there compatible with "auto brand". The warranty dealer can not deny the warranty without proving the abc brand caused the problem.
Also In disputing the void warranty claim there should be info in the warranty paperwork to who you can contact or work through. Or you can go through the F.T.C. they should be able to guide/help with the issue.
I'm sure your not the first person to do a fluid change that did not use the nissan fluid.
09/18/2011 3:53 AM
i'm sure nissan has an air tight case. proprrietary fluids are always called for under any car manufacturers warrentty conditions. jiffy lube would be considered the experts as far as using the correct fluids. when it doubt, sue everyone involved.
Good Answers: 46
09/18/2011 5:03 AM
If a proprietary fluid is call for by the warranty the warrantor can not charge for it under the Magnanimous-Moss act unless it is stated in the warranty. They can not void your warranty by you having your work done somewhere else(tie-in clause). Just as long as you can prove the proper scheduled was followed.
It all comes down to just what is in the warranty. That is your contract. NOT verbal as a service manager that says its so.
It come down to the manager is trying to make money for the shop every warranty job will cost the shop money cause manufacture only pays on scale. Where consumer pays labor, parts, overhead of shop, etc.
Anonymous Poster #2
09/18/2011 9:30 PM
If the green fluid is really the same, just dye it red....why do they need to know?
Good Answers: 46
09/19/2011 1:39 AM
I believe the original Nissan fluid is green the aftermarket is red.
09/19/2011 1:49 AM
Oops, but same difference.
Where is Tenneesse?
Good Answers: 46
09/20/2011 10:27 AM
Tornado, Tennessee is due east of Arkansas.as if you did not know I live a slingshot throw from the mountains and a stones throw from the lakes in east Tn. Nice place to live. most of the time.
Though red and green, I guess you could mix them up if colorblind. Or mix them together and get an ugly color.
09/20/2011 6:32 PM
this is true. When I replaced 6 quarts of the red with green, the fluid was still red. Red trumps green.
09/22/2011 11:07 PM
Wait. Whaat? Then how did Nissan know that it wasn't theirs?
In reply to #75
09/22/2011 11:09 PM
Nevermind, I had it backwards.
Good Answers: 74
09/22/2011 7:37 PM
If you mix those you will get brown
The Twain Has Met
Good Answers: 123
09/21/2011 10:48 AM
Why don't you try contacting the area manufacturer's service representative. The warranty book should have a detailed procedure outlined in the back for dealing with disputes. Be sure to have the documentation for the fluid that is in question. If the product container has a statement on it that states that it meets the manufacturer's standard XXX-123, than the manufacturer will have to either honor the warranty, or dispute the fluid manufacturer's claim.
I would suggest that you sit and try to read the warranty book supplied with your daughter's car and then act according to the information contained in it. You may also be covered for a rented vehicle for the time you are without a vehicle after a reasonable period of time.
Tranny fluids are not all the same. My S-10 manual has 2 different 5 speeds transmissions used, based on which engine you ordered. Each one uses a different fluid. One version recommends ATF, while the other one uses something strange. I think it was called synchro fluid. Not even the old 85-140 multi grade gear oil. On something as unique as a CVT, that is a Constantly Variable Transmission, The control of slippage has to be very critical. That is why there is so much of an issue over the type of fluid used.
Bob
Good Answers: 74
09/22/2011 10:00 PM
Hi Sloopster3
Is your daughter following this? She might get a good laugh out of it
The Twain Has Met
In reply to #64
09/22/2011 10:08 PM
In reply to #66
09/22/2011 10:15 PM
09/22/2011 11:16 PM
Can some moderator please come along and get rid of both of these dueling users?
In reply to #77
09/22/2011 11:40 PM
I'm trying my hardest not to argue (obviously it's not working). But I agree, that would be a great idea. The only question I ever had to ask on here was answered.
If it really bothers you though, just unsubscribe. That's what I'm about to do.
In reply to #78
09/23/2011 12:04 AM
Good. One down, one to go.
Good Answers: 46
09/23/2011 1:07 AM
Kevin your not doing too good here.
Yes most fluids in an auto can be misapplied and it will work. BUT the thing your NOT willing to acknowledge IS THE SEVERER SHORTING OF THE LIFE OF THE COMPONENTS THAT HAVE HAD THE WRONG FLUIDS PUT IN.
I made the mistake of putting brake fluid in the power steering pump. The idea was to swell the seals to get a little more mileage to slow a bad leak up in the mountains 4wheeling and needing the power steering and was out of atf & power steering fluid. After about a few hours of running the entire power steering system either had to be replaced or rebuilt. Every seal, hose was ruin.
I also don't doubt that a older GM, Ford, Dodge, etc or any other automatic that uses mercon, dextron, or whatever will work with the wrong fluid and may live for several thousand miles or more. BUT something designed for a hundred thousand miles plus WILL NEVER SEE ITS MAXIMUM MILES/LIFE.
As to most automatic transmissions. The torque convert couples the engine to the trans. The convert is coupled to the pump that generates the pressure to operate the pistons that engage the clutches to couple the different gears. The torque converter also couples through the vanes/stators a shaft that drives the gears based on the clutches selected. The life of the fiber disks, seals etc will be compromised with the wrong fluid. But it will work till then.
The OP's trans is a CVT "Continuously Variable Transmission" The operation is vastly different than the trans in your car. Some use two pulley's with a belt between. The pulley's will very in width based on speed/torque needed. To make the parts lasted the longest the "fluid" is made to handle the friction and lubrication needs of the trans. So the wrong fluid would ruin the trans in a very short time. Unlike in your car.
Try reading up on Tribology. Its the science and engineering of interacting surfaces in relative motion. It includes the study and application of the principles of friction, lubrication and wear. Tribology is a branch of mechanical engineering.
Here a Google link for further study. You may even find a book or to too download to read.
I don't know "you" or your "education" or your "experience". BUT you, what you have posted does not bode well for you. You are a lot like my friend. He thinks he knows it all. As soon as something breaks he wants help. And I do what I can. After fixin it a little later he tweaking again to make it do something it can't. Its a merry-go-around with him.
Anyway try to keep learning and be willing to learn. CR4 is a good place. But if your after the backyard-shade-tree don't know what your doing, thinking,that $600.00 car with the $20.00 gizmo gonna make it run like a $200,000.00+ top fuel dragster. Just keep on smok'in, drinking, or whatever your choice of poison is and believing.
#83
In reply to #80
09/23/2011 11:38 AM
I see what you're saying, and you explained that very well. Although I still doubt that if someone were to use the wrong fluid, it would shorten the life of the transmission. More-so the life of the fluid, and slightly the life of the transmission. Of course it shouldn't be done on purpose, but if it were an accident, then you wouldn't necessarily have anything to worry about.
In reply to #83
09/23/2011 4:29 PM
OK, here we have what I think is the discrepancy in communication. You are making the reasonable point that a brief exposure of a transmission to the wrong grade fluid in a pinch will likely not make significant damage. Until this posting you've not made this clear. I and I believe most of us here will say that this is a plausible position but not necessarily true for all transmissions and fluid chemistries. I am particularly circumspect of this being true for a CVT, but these transmissions are so new to passenger vehicles here and operate so differently than a traditional automatic transmission that I won't presume what will happen. However, leaving the wrong fluid in a transmission (particularly all of it being wrong) until something dies (the scenario I and most of us thought you were advocating), will make something die sooner rather than later.
Good Answers: 123
#82
09/23/2011 9:14 AM
To the best of my knowledge, Ford Motor Company was the last to use asbestos in the friction materials of their automatic transmissions. For this reason the world was blessed with type A and type F automatic transmission fluid. The Ford motor company people told us that type A fluid would dissolve the friction material in their transmissions. Dextron was supposed to be usable in place of either fluid, but by then, there were so few transmissions that were still using the asbestos friction materials in them, that any shortcomings in Dextron would have been few. But back when automatics were in their infancy, there were different fluids. Using one or two quarts in a system that relies on 12 quarts would not make a dramatic difference, but using twelve quarts of the wrong fluid sure will.
The OP did not proclaim to have added a quart of the wrong fluid, he had all of it changed. And the CVT is still in its infancy in over the road vehicles. The friction point of the belt inside it is very critical to the car accelerating under load. What do you think would happen if you got oil on the clutch disc of a car with a manual transmission? What about getting water water in the brake drums of a car with drum brakes?
If the belt in that CVT is allowed to slip by an additional ten percent, the car will act just like a slipping clutch, and rev up too high. That additional high speed slipping will just wear out the belt, or the "pulleys" that it is designed to grab.
Instead of trying to defend your stand on the post, try to think what additional friction, or reduced friction in that PARTICULAR transmission would do. In one case, it would slip too much to be drivable, and in the other case, it would bite too much and bog down the engine, or possibly stall the engine out.
Bob
Register to Reply 84 comments
Anonymous Poster (2); bob c (7); kevin12340 (27); ky (2); lyn (6); metalSmiths (8); pantaz (1); redfred (7); SimpleMind (1); sloopster3 (2); Smoothy (18); Tornado (3)
