Previous in Forum: Water Ring Vacuum Pump   Next in Forum: Shaft Design to Avoid Breakage
11 comments
Torque Calculation - 1 Motor Connected to 2 Gearboxes in Series
09/20/2011 2:48 AM
Halo,
I have one motor connected to two gearbox in series.
Motor is Ac motor of 30Kw and 6Pole.
This motor is connected to first reduction gearbox which is having 1/8.96.
The fisrt gear box inturn connected to secound gearbox which is having 3 out put universal joint shaft drive which is driving 3 rolls.
The ratio of secound gearbox is 1/1.70.
Question is if i have to calculate the output torque on the universal shaft, should i consider the power of motor is distributed equally to these 3 universal shaft? i mean here each shaft will have a power of 10Kw?
or i can consider that power of the motor ie 30 kw is transferred to all shaft?
Hope my above writings are clear....
please let me your comments.
Regards,
RR
Pathfinder Tags: torque calculation
Re: Torque calculation
09/20/2011 4:57 AM
  • It is the load that determines the torque at the gearbox.
  • It is the gearbox that determines the speed and torque needed from the motor.
  • It is the torque at the motor that determines the current drawn from the supply.
  • It is the voltage at the supply together with the current draw that determines the input power of the motor.
Re: Torque Calculation - 1 Motor Connected to 2 Gearboxes in Series
09/20/2011 10:28 AM
Each of the three final shafts receives 10kw (less small losses) of power; thus use 10kw as the basis for calculating torque.
09/20/2011 10:44 AM
The forum doesn't know what the rolls are driving yet. If there is slippage or stretching then the statement may not be true.
09/20/2011 11:12 AM
Hello,
Universal shaft connected to roll which in turn move the pipe in a conveyor.
Above all are part of pipe straightening machine.
Regards,
RR
09/20/2011 12:40 PM
In this case, the torque may not always be distributed equally. To be on the safe side, it would thus be better to design each shaft to accept the total power input; and also any initial surges as the pipe engages each roller.
09/21/2011 10:09 AM
Quite. GA
Good Answers: 137
09/20/2011 3:17 PM
I don't know whether others can visualise that, but I can't. What is a universal shaft in this context? If you just mean it's a shaft (or 3) with Hooke joints, that detail is irrelevant to the torque question.
Does the 2nd gearbox have 3 output shafts, all running at same speed? Are the loads on the 3 shafts controlled in any way? If not, in principle you could have all 30kW going to one shaft, and it wouldn't be a problem as long as the gearboxes can take the torque. Not sure what you're asking.
Codey
09/21/2011 5:01 AM
The amount of power consumed by each shaft depends on the load on each shaft but the sum of power consumed by each shaft added with losses in both gearboxes cannot exceed 30 KW
09/21/2011 11:33 AM
The load is what really matters. If you can't accurately estimate that, then 30kW is your answer as safety > $$$.
09/22/2011 2:25 PM
If, for any reason, the shafts do experience a torque requirement of 30kW each, then the g-box will be O/loaded!
For that reason, The OP must make sure that the total is < 30kW during the worst case. For each shaft, the load will depend on the process and design of the machine.
Then, designing each shaft connection to take 30 kW is an overkill.
Good Answers: 137
09/22/2011 2:49 PM
It's time ralish came back and commented on advice given, and clarifies what he's doing.
Codey
Register to Reply 11 comments
Codemaster (2); LAA_Lucke (1); NicolaTesla (1); PWSlack (3); ralish (1); shujabutt (1); Tornado (2)
