Previous in Forum: Need to Find Main PCB Assembly   Next in Forum: Tech Jokes
I Want to Know the Size of the Sand Sieve am Using
09/21/2011 9:47 PM
During the routine surface well testing activity we carryout a sand check on the well sample to ascertain the sand production of the well being tested.The sieve we are using to sieve the sand particles from the liquid is getting old and there is no previous record of its size, and there's a need for me to purchase a new one.Please, can someone help me with the right size of the sieve?
Habib Dan kawu
Chesroc Nigeria (oilfield services) limited,Port Harcourt.
Pathfinder Tags: sand sieve
Re: I want to know the size of the sand sieve am using.
09/21/2011 9:54 PM
If it's a purchased sieve, it will have the mesh size stamped on it.
Did you look?
You can send it to a lab for analysis, but you'll have to pay for the service, so, that's probably out.
09/21/2011 11:00 PM
The overall size can be simply measured.
The screen mesh can be counted as so many wires per centimeter or inch, using a magnifying glass, jeweler's loupe, or microscope as appropriate. Individual wires can be unwoven and measured with a micrometer, making it possible to compute the opening size. Or, wires of various gauges can be inserted into the mesh to see what fits.
09/22/2011 12:47 AM
could it be as easy as measuring the size of the particles that are able to pass though the sievee? , or do you need a factual measurement of the screen [wires?] spacing?
Good Answers: 179
09/22/2011 8:23 AM
You can use machinist's wire gauges to measure the mesh openings. Do this at least 10 to 20 times to get a good mean average size reading.
If the mesh appears to be worn or there's evidence of heavily corrosion you may have to purchase a new well screen that has mesh openings one or two sizes smaller than your existing screen.
What type of mesh material is it?
Good Answers: 137
Re: I Want to Know the Size of the Sand Sieve am Using
09/23/2011 8:40 AM
Why don't you take it with you when you go to buy the new one, and ask them to match it? A sieve supplier should have no problem identifying the mesh size.
Codey
Anonymous Poster (1); CaptMoosie (1); Codemaster (1); lyn (1); Tornado (1)
