Previous in Forum: Build Question: Van Der Graaf Generator - In a Car?   Next in Forum: Magnet Motors Effeciency
MHD Generator Head for an Oscillating Fluid Flow
09/21/2011 11:17 PM
My work involves design and development of external combustion engines, and - at a friend's urging - I've been strongly considering adapting one of the engines to produce electricity using a pair of MHD generator heads. I've done enough research to conclude that the particular engine and MHD generation may be a near-ideal match.
I've found what appears to be a comprehensive document on MHD, and am hoping that folks here can help me understand it well enough that I can design a practical generating head and tailor the engine design to optimize its performance.
I'm not looking for anyone to do the design work for me, nor do I want to pollute the EE section here with ME/thermodynamics stuff (although I am perfectly willing to talk about those things elsewhere. )
The fluid media is supercritical water which can contain just about any ionizing agent soluble in sc water, the magnetic field strength can be anything reasonably achieved, the flow rate is a design parameter, and so is the cycle rate. In other words, all options are wide open and I'm free to tailor engine behaviors to whatever works best with the MHD heads used.
For anyone who'd like a look, this web page has a number of concept sketches.
Pathfinder Tags: fluid generation MHD Stirling
Re: MHD generator head for an oscillating fluid flow
09/21/2011 11:49 PM
This sounds like an interesting spin-off of sugarandfat's thread, and with luck may lead to some cross-talk between the two.
Right now, the only thing I know about MHD is what the letters stand for. Nonetheless, here may be a stab-in-the-dark conjecture: The flow rate of ions should correspond to current output, and the velocity may correspond to voltage output (big ?? especially on the latter).
On that very tentative basis, I did not see an advantage to diverging/converging nozzles or piping sections. For the moment, I'm just along for the ride, but I anticipate enjoying and learning from the threads and sites. Best of luck to both on your respective projects.
09/22/2011 12:07 AM
He and I have been corresponding/collaborating for some time on seperate but related projects.
I think you're close, but the magnetic field is what "drives" the ions to the electrodes - so field strength is also an important part of the picture.
This project really needs involvement of ME, EE, and physics types, and I'm wishing that discussions could be linked (joined) across CR4 sections for better collaboration.
Good Answers: 59
Re: MHD Generator Head for an Oscillating Fluid Flow
09/23/2011 3:31 AM
I recall from a good generation ago, that MHD generators were a good idea for very high power. Erosion and cooling were the problem. Modern materials, maybe.
Go for it! Even, if you do not succeed completely, you have more than fair chance to advance the state of the art.
09/23/2011 10:22 AM
AFAICT, much of the effort put into MHD was intended to improve efficiency of existing generator stations by adding a secondary energy extraction process to recover as much as possible from an (otherwise wasted) plasma stream.
One of the unavoidable drawbacks was that the hot gasses exiting the MHD head still carried away a significant amount of the original plasma stream's energy. My expectation is that by installing MHD heads in a closed system with an oscillating flow, the generation process overall efficiency will benefit from repeated passes of the ion-carrying media through the heads.
The approach I'm taking only requires 374-400°C operation, and media velocity will be considerably less than I would expect in a plasma-based system, so erosion is likely to be less of a problem. If electromagnets are used, cooling may become completely unnecessary, which (all by itself) might constitute a significant efficiency improvement.
I'm proceeding at full speed with a two-pronged approach: one will use a trough-type parabolic solar concentrator to power the reciprocating flow, and another will use an embedded Ni/H fusion reactor in a similarly-configured engine to power the flow. The fusion reactor is unproven, and will probably absorb most of my attention through the coming winter. If I have to master MHD alone from scratch, developments will proceed much more slowly, but I'm fairly certain that at least one of the two approaches will be successful.
I doubt that I'm doing much to advance the state of the art, since almost everything I'm doing involves fairly well-established/known principles. All I'm doing is attempting to connect old dots in a new way.
Register to Reply 4 comments
leveles (1); mrdovey (2); Tornado (1)
