Previous in Forum: How to Communication Between Laptop & SIEMENS PLC S7-200CN (Made in China)   Next in Forum: 15 MVA Power Transformer
22 comments
Busbar Calculations
09/26/2011 2:54 AM
How to calculate size of copper busbar strip required to carry 6000A DC and 6V for electrochemcial application ?
Thanks
Vinith
Good Answers: 181
Re: Busbar calculations
09/26/2011 3:10 AM
Use the "search this forum" feature on the right hand side of the screen.
09/26/2011 3:34 AM
Total shot in the dark: 25mm x 150mm.
09/26/2011 5:07 AM
Is it the thickness X width ...waht you have mentioned ?
If so is there any chart mentioning busbar carri ying above 5000 A current either in copper or aluminium
09/26/2011 5:10 AM
What else would it be, other than thickness and width?
(And it's copper, as mentioned in the OP; rather than aluminum, which was not mentioned.)
09/26/2011 5:17 AM
As copper is told it cant carry above 4500A ....My requirements needed upto 6000A so will there be problem using copper
09/26/2011 5:30 AM
Then make it wider and/or thicker, or two busbars in parallel.
There have been many threads about this on CR4, oftentimes mentioning 1100 amperes per inch2 ≈ 1.7 amperes per mm2 for copper. There is some variation depending on surface area and ambient temperature. For better heat dissipation, if needed, you could go thinner but wider.
Google "busbar calculation" or "busbar area" to discover more.
If you want to be fancy (least area), you could use silver....
09/26/2011 6:58 AM
What should be the heat calculations for 1 in X 6 in Copper busbar ?
India - Member - New Member
Good Answers: 164
09/27/2011 10:57 PM
Who sold you that bovine output? i have worked with 180000A copper busbar in a chemical plant....
09/27/2011 11:58 PM
Hello Sir,
Can i have your contact number am Vinith Gandhi R from coimbatore,Tamilnadu....B.tech.Electrochemical Engineering.....I like to have somw word with you
Good Answers: 181
09/28/2011 7:49 AM
That is a beautiful bit (lot) of copper work
09/26/2011 4:05 AM
should it hurt bad to touch the busbar with dc supply? if no, may be I touch today.
Good Answers: 181
09/26/2011 6:48 AM
I've used 3/8 X 8" for 4000A so go for 3/8 X 12"
09/26/2011 7:02 AM
Width6in152.4mm
Thickness1in25.4mm
Copper Ampacity1000A/sq.inches
Current carrying capacity6000
Is this correct ?
if so what would the heat generated for this sized copper busbar ?
09/26/2011 7:03 AM
Width6in152.4mm
Thickness1in25.4mm
What is the heat calculation for this busbar size ?
Re: Bus-bar calculations
09/26/2011 7:41 AM
As i mentioned it is 6000A DIRECT CURRENT with 8 volts ......
Operating Temperature : 32oC
Process : Electrochemical
Material of interest : copper
Conditions: The is no voltage fluctuations as it is a potentiostatic rectifier
Has to be welded to Nickel Electrodes
Help me out in
1.Size calculation
2.heat generation formula
3.insulating the bus-bar
4. how to take connections from busbar to electrodes ? Through whar king of wires ?
09/26/2011 1:51 PM
You are obviously not qualified for the job you seem to have. Any first year apprentice wireman can figure this out.
09/27/2011 2:21 AM
Sorry am an Electrochemcial Engineer am not as much as you in Electricals
Good Answers: 181
Re: Busbar Calculations
09/26/2011 9:11 AM
You asked this same question on 12-08-11
09/27/2011 5:54 AM
Were the answers the same?
09/27/2011 7:59 AM
So 7/.029 is too small, then?
09/27/2011 8:08 AM
Dear PWSlack,
Can you explain me clearly :O
Thanks
Good Answers: 181
09/29/2011 10:44 AM
Until "you" can explain yourself clearly how are we supposed to explain "you" to yourself clearly?
Register to Reply 22 comments
Anonymous Poster (1); kvsridhar (1); lyn (1); PWSlack (2); TonyS (5); Tornado (3); vinith (9)
