Previous in Forum: P0420 Code After Engine Misfire Repaired (P0303)   Next in Forum: Automotive Starter Motor Solenoid Design
Possible Bad Alternator
10/01/2011 1:16 PM
I've got a 1999 Dodge Caravan mini van. I'm getting the feeling the alternator isn't feeding the battery.
Back in the old days when I knew how to work on cars, I would just pull the positive terminal while the car was running to check the alternator.
Is it still okay to use this method with the newer cars, or will it mess something up?
Good Answers: 114
#82
In reply to #77
Find in discussion
Re: Possible Bad Alternator
10/05/2011 2:36 PM
Actually the internals of the solenoid are a connection
hey it's just a big relay after all, when the contacts get too oxidized, too much resistance
looks like the solenoid piggybacks on the starter
the way to check is to take a pair of pliers or a couple of screwdrivers & jump across the terminals on the solenoid & see if the starter turns faster
course the point is moot, as the starter has already been replaced
you may have even be able to replace just the solenoid
In reply to #82
10/05/2011 3:17 PM
I tried. It was a no go. Complete unit only.
Which is fine. If I went that route, I'm sure it would have been the starter motor.
Now that I think about it, I think some Arizona paint over spray drifted all the way to NC and gummed everything up. At least I can tell my attorneys the general location of the parking garage that was being painted and caused it.
In reply to #83
10/05/2011 4:14 PM
You'll need an attorney. He'll hire keverne to investigate the causes of the loss.
Man, I've never seen so many people whine because I wouldn't blindly follow the "expert advice" given to me by total strangers.
Good Answers: 70
#85
In reply to #83
10/05/2011 5:17 PM
You should have waited a day, I'm sure one of those Arizona dust storms would have came up and sand blasted your starter for you and solve your problems. Yes, I know Lyn, that was in poor taste, those dust storms are no joke! I have friends in AZ, and have been stuck in them, it's just I couldn't resist and pass that one up.
Good Answers: 114
#87
In reply to #83
10/06/2011 8:14 AM
I've taken a ford external solenoid & a short battery cable to do a permanent bypass on a peugot with a solenoid piggybacked on the starter, where the starter was gonna be expensive & 2 weeks away
many times the solution to a technical problem is dependent on the materials available, timeframe & budget
Good Answers: 123
#88
In reply to #87
10/06/2011 8:54 AM
Form follows function. One of the solutions to starter failures on motor homes with big block Chevy motors was to add a remote starter solenoid (Ford) to lower the heat problems that the vehicles were experiencing.
Bob
In reply to #88
10/06/2011 1:09 PM
A K A- Necessity is the mother of invention.
I have a big block V8 in my GMC truck. The little ignition module that sits in the bottom of the distributor kept going out. I assume because of heat. I couldn't find one that would last.
Finally ended up ripping it out and installing a Crane ignition system. Problem solved!
Good Answers: 123
#90
In reply to #89
10/06/2011 2:50 PM
MSD makes a neat ignition conversion for the large distributer cap GM ignition systems. You use the original GM pick up, leading to a remote MSD unit, then running to a remote ignition coil ( better spark above 4000) then back to an adaptor that brings the high voltage into the distributor and sends it to the rotor, and then to the plug wires as original. The one I had outlived the car. I sprung for the adjustable timing control. It allows up to 15 degrees of retard. By setting the initial timing 7.5 degrees advanced from normal, you end up with 7.5 degrees of advance or retard from what was the original setting. Great for squeezing mileage on a trip. Just hold the throttle steady, and move the timing knob located within easy reach and watch the speedometer. If speed goes up do it again. If it goes down, go in the other direction. When speed will not increase, you are right where you want to be.
Bob
In reply to #90
10/06/2011 3:33 PM
It was a tough call between Crane and MSD. I forget now what little piece of information pushed me into Crane.
I have the timing control on my dash too. Pretty cool!!!
I put the Crane in about 5-6 years ago, along with a high performance cap, plugs and wires. Haven't touched it since. It still loves gas though. If I'm real gentle, I can squeak about 13 MPG out of her. It's a 454.
The good news is, my neighbor got a new Chevy truck a few years ago. It has the V8 Vortec I think. Big block. Mine is an 86, and our gas mileage is about the same. Go figure.
Good Answers: 123
#91
In reply to #89
10/06/2011 2:51 PM
If Necessity is the mother, Lazy is the father.
Bob
Good Answers: 70
#94
In reply to #89
10/06/2011 4:06 PM
GM came out with a service bulletin in 1978 on the HEI ignition systems, requiring using only White Delco rotor caps and change the rotor cap at every tune up. Any other rotor cap couldn't handle the high voltage. They would burn thru the center of the rotor and ground out on the inter-shaft,(for the mechanical advance). It would not only take out the ignition module, it would also weld the distributor's inter-shaft to the bushings! I made a ton of money taking those distributors apart and polishing the inter-shafts and reselling them. Never had a come back with them
In reply to #94
10/06/2011 4:38 PM
Those engines get hot. My problem was strictly with the module. It would get hot and cut out..................after it cooled off, it would be fine again. Pain in the a$$.
In addition to the Crane ignition, I went with Accel high performance HEI cap and wires. Everything works awesomely. If something works great..........I'll plug it.
Nice idea to generate money!
Good Answers: 70
#96
In reply to #95
10/06/2011 5:18 PM
Good Answers: 70
#93
In reply to #88
10/06/2011 3:36 PM
I don't know how many Chevy engines I seen where someone removed the heat shield from the starter! Which they also suffered a higher than normal stater failures.
Location: Ground Zero of the Pompous and self important....Washington DC
10/07/2011 12:14 PM
I didn't read the ENTIRE thread to see, but if it hasn't been mentioned, pulling either battery cable off while running is a hugely bad idea.
At the very least, the transient you put on the system was likely to damage or fry the diode pack or the regulator, and at worst you can damage the ECU and every other electronic device attached to the vehicles power.
In reply to #97
10/07/2011 12:32 PM
apparently you haven't read any of the posts
In reply to #98
10/07/2011 12:51 PM
I read about a dozen of them.....and none warned of the very real and very serious risks to doing it. I had post #97 after all.
Thats why I stated I didn't read the entire thread at the begining of the post.
Good Answers: 123
#100
In reply to #99
10/07/2011 1:06 PM
Don"t let this happen again. If caught a second time, you will be required to read the entire bath breaking thread aloud.
Bob
In reply to #100
10/07/2011 1:22 PM
sdrawkcab, to boot.
Good Answers: 123
#112
In reply to #101
10/10/2011 1:19 PM
sdrawkcab ???????????????
Bob
In reply to #100
10/07/2011 1:46 PM
...........Not the 100 lashes with a soggy noodle punishment....
Good Answers: 145
#103
In reply to #97
10/07/2011 8:58 PM
I wrote about it, see reply #9
Andy Germany (13); Anonymous Poster (1); autotechnocracy (1); bob c (15); Codemaster (11); dj95401 (10); DRFREON (4); Garthh (7); grandpaw (2); Haajee (1); joshroberts (1); JWthetech (2); K_Fry (1); KeepItSimpleStupid (4); KJK/USA (1); kramarat (24); lyn (11); Smoothy (6); snatr (1); Tobugrynbak (3); vtbgiraud (1); Z man (2)
