Previous in Forum: question   Next in Forum: Transformer Differential Settings
13 comments
Transmission of Power
10/07/2011 2:35 AM
Is it possible to transmit power through waves ?
Re: transmission of power.
10/07/2011 2:44 AM
Yes. But how much?
10/07/2011 2:45 AM
Yes if you don't mind getting wet.
10/07/2011 3:46 AM
A wave can be a very powerful gesture.
10/07/2011 4:57 AM
This should do the trick... plenty of power.
India - Member - New Member
Good Answers: 164
10/07/2011 5:27 AM
....and with a reward
Waaaave
Good Answers: 67
10/07/2011 4:03 AM
Mechanical power transmission systems like belt drive, chain drive, magnadrive or gearing ect. require a power source like electric motor or IC engine to connect a driven machine. Electric power is transmitted through cables.
Here, it is not clear which power you want to transmit using waves as a medium. What is the source and which machine/ system is to be driven?
Re: Transmission of Power
10/07/2011 8:07 AM
No.
You can transmit energy through waves, but you cannot transmit the rate at which that energy is converted (i.e., power) through waves.
10/07/2011 12:35 PM
What kind of waves?
Light, heat, water, air, hand, radio/electromagnetic, or amber grain?
10/07/2011 11:57 PM
If solar energy(light/heat/IR/UV etc) can reach earth why can't we transmit electricity too. Recently Germans have made a device for charging EV battery without using a cord
from a wall mounted charger.
pnaban
10/08/2011 2:47 AM
Of course we can, it's just a silly idea, for all the reasons which have been explaiened many times in many almost identical threads.
And I believe the EV charger is V short range induction, hardly what is commonly meant by 'waves'
Good Answers: 130
10/08/2011 12:38 PM
Air cored transformers tend to be not very efficient - they are sort of thing that is 'forgivable' for electric tooth brush charging.
But what does it matter if your electric car is hooked up even less efficiently to the coal fired power station?
10/09/2011 7:02 AM
are'nt "waves" by definition refer to power being broadcast from another source of power?
Good Answers: 130
10/09/2011 5:48 PM
How true
Register to Reply 13 comments
34point5 (2); Anonymous Poster (1); kvsridhar (1); lyn (1); pnaban (1); pritam (1); PWSlack (1); Tornado (1); Usbport (1); user-deleted-1105 (3)
