Previous in Forum: Need to X Cut Aluminum Extrusion & Get a Good Finish.   Next in Forum: Batch Number Reader (Sensor/Camera)
8 comments
Estimate Force for Spinning Forming
10/09/2011 12:58 AM
Dear All
Thanks inadvance for your kind attention.
Is there any one to show me how to estimate force for spining forming a metal plate.
As you know, heads of pressure vessle are elleptical form.you will find in attchment a sketch to clarifing force and mechanism of forming.
Please be informed material is carbon steel. kind Regards,
http://files.engineering.com/getfile.aspx?folder=22755428-8fca-4e1a-9446-77
Re: Estimate force for spinning forming
10/09/2011 2:00 AM
This may be a complex calculation, beyond my experience. Some of these references may help.
Welcome to CR4. Your diagram was very clear, and the question is among the best I have seen.
(A very minor note: the drawing is of a torispherical head rather than elliptical. To the untrained eye, these are almost alike, and there would be only small differences in the forming forces, which would depend on how close the forming balls are to each other as the operation progresses.)
The best CR4 experts for this would likely be Abdel Halim Galala and Nick Name.
Re: Estimate Force for Spinning Forming
10/09/2011 10:19 AM
You might ask these guys: Global Metal Spinning Solutions, Inc. or DENN USA Metal Forming:Machinery Program Overview.
I've never seen metal formed the way you have drawn it. All the metal spinning I've seen is done by forcing the metal to conform to a round mandrel that is the final shape of the part, sometimes using heat.
Tornado is correct, the two gentlemen he names likely are the most knowledgeable on the subject.
Good Answers: 204
10/09/2011 11:03 PM
10/09/2011 11:09 PM
That makes two of us.
Good Answers: 59
10/09/2011 11:16 PM
At the risk of being tangential, there is a metal forming technique in sheet metal forming called the English Wheel. The results are wonderful one-off pieces. the practicioners are more of an artist, than a technician.
The more technical one is explosive forming. The explosion takes place in water, and in one step the sheet metal is plastered on the inside of the form. Again, it is the work of artists of an "ahem" different kind. Not for the timid, that's for sure.
Then there is the good old-fashioned stamping, you seems to want to avoid.
10/09/2011 11:30 PM
English wheels form gentle curves, not end caps.
"Explosive forming" is more likely explosive joining, which is how they used to make the nickel clad copper coins. It joins two metals with no intermediate processes.
I'll give you hydroforming, if you want to look that up.
But, the term is metal spinning. Ok, mis-used as spinning forming.
10/10/2011 9:26 AM
OOPS.
You are right about explosive forming.
I stand corrected.
10/10/2011 9:27 AM
Not that this will answer your question, but unless my mathematical skills are eroding, if the true radius of R1 is to be R1=0.173*D, R1 should equal 432.5 and not 423.5
"Money talks I know, I heard it once, it said Goodbye”
Register to Reply 8 comments
chrisg288 (1); leveles (1); lyn (4); Qwack (1); Tornado (1)
