Previous in Forum: Estimate Force for Spinning Forming   Next in Forum: Nace Standard and PWHT
Batch Number Reader (Sensor/Camera)
10/09/2011 10:49 PM
i have 2 questions:
  1. for reading batch no/codes printed on carton/aluminum foil/packaging material, in addition to using an suitable keyence camera/sensor, the other not less important thing is, how to ensure a camera/sensor works as expected (valid) at anytime of use?
  2. when using camera is visual inspection no longer needed?
thank you.
Pathfinder Tags: AS
Re: Batch Number Reader (Sensor/Camera)
10/09/2011 11:04 PM
There is always a need for checking that any sensor is working correctly, vision system or not.
Generally however, barcode reading is pretty routine nowadays.
Why are you concerned about this?
10/10/2011 2:55 AM
Thank you for the comment.
Simply because of zero defects "Quality Assurance"
Not any of what should be "batch no/code" printed is distributed to the customer without.
Canada - Member - New Member
10/11/2011 12:11 PM
You simply need to require a good reading of the bar-code before your operation continues. Good reading equals continue, no or bad reading sorts the item or stops the line.
Knowledge makes what was impossible, seem easy.
Register to Reply 3 comments
Arianto Soebagio (1); Elroy (1); Mikerho (1)
