I was going through catalogs of schneider electric NSX circuit breakers and I found this, electronic (micrologic) trip units 1-5 doesn't have inbuilt ground fault protection, But micrologic 6 has a ground fault protection inbuilt and its setting is (0.4-1 )x In. In being the nominal current. so I have 3 queries.
1) Does a normal MCCB protect against phase to ground faults
2) If no, is Micrologic 6 the only option for protection against ground faults. because ELCB or Vigi modules are only for earth leakage protection
3) If yes, why specify it as a separate term or a additional feature in Micrologic 6.
I still didnt get proper answer for my previous post.
http://cr4.globalspec.com/thread/72715#newcomments
thank you
