Previous in Forum: Unit Conversion   Next in Forum: Nozzle Diameter
Booster Pump
10/17/2011 9:22 AM
Dear Sir,
What is the diffrence between booster pump and transfer pump. ( Mechanically and Functionally).
Thanks and Regards
Vani
Re: Booster Pump
10/17/2011 10:16 AM
Really, you should learn how to perform a search for this elementary information.
The asnwer is, not much, but you could find this out by performing a simple search.
What is the difference between booster pump and transfer pump
READ THESE!!!!!!!!!!!!!!!
How to Search the Internet Effectively
How to search for Internet resources to use in a lesson
Finding Information on the Internet: Table of Contents
Re: Booster Pump
02/23/2012 6:54 AM
Dear Sir,
Thanks 4 your explanation and links..Acutally CR4 also comming in this list. I already went through several links which is provided by google, yahoo and other search engines, I consider The CR4 gives a better definition regarding this because of the talented Gurus. Please dont consider these are silly questions because in my level it is a difficult one.
By.. Vani
Good Answers: 266
Re: Booster Pump
10/17/2011 3:59 PM
The noun describing the functioned design of the pump and it's definition.
Re: Booster Pump
10/18/2011 7:35 AM
it's its
Good Answers: 19
Re: Booster Pump
10/17/2011 10:37 PM
Pumping from ground level to Over head Tank = Transfer Pump.
No Over head Tank - Distribution System pressurized via Booster Vessels = Booster pumps
Re: Booster Pump
11/17/2011 2:10 AM
I think Booster pump consistes of three parts & give you variable flow rate according to the demand
For example : Say Booster Pump Parts are (A+B+C)
A give 55% flow rate -B give 55% flow rate -C give 25% flow rate
If your demand is 55% or less then pump A working in service
If your demand is 80% or less then pump A&C working in service
If your demand is 100% then pump A&B working in service
So you don't need a gravity tank
Re: Booster Pump
02/22/2014 4:34 AM
dear VANI,
Booster Pump is working on-line and it will deliver to the other Pump Suction, No throttling, etc.
Transfer Pump is just to transfer the liquid to another vessel/tank. Here throttling/regulating the flow is acceptable.
DHAYANANDHAN.S
Register to Reply 7 comments
Anonymous Poster (1); dhayanandhan (1); ducon (1); lyn (1); ozzb (1); samy.m7md (1); Vani (1)
