Previous in Forum: Telescope Focusing Problem   Next in Forum: Pump Running Indication
Steam Turbine
10/19/2011 12:54 AM
steam turbine is tripping on low control oil pressure of governing system .what may be the reason
Pathfinder Tags: chemical engineer
Re: steam turbine
10/19/2011 1:46 AM
Wrong setting of an oil pressure regulator somewhere.
Wear in the oil pump, so that it cannot produce adequate pressure and/or flow.
Significant oil leak(s).
Plugged filter, blocked piping, or some valve partially closed.
Etc.
Re: Steam Turbine
10/20/2011 4:20 AM
The reason is that the control oil pressure is lower than the setting on the trip device.
Register to Reply 2 comments
