Previous in Forum: KOKEN Barber Chair   Next in Forum: General
QuickCad 8 Doc 13 in X 36 In Will Not Print to Epson Workforce 1100
10/28/2011 5:12 PM
I am having trouble printing a drawing from QuickCad 8 to my Epson Workforce 1100. The printing machine seems to work fine but in QuickCad 8 the Page Setup dialogue box and various tabs do not let me get the job done. On the Size tab I am able to select the "Customer Size" radio button and define the size as 330 mm X 910 mm with no problem, but the "tiling" function automatically takes effect in the graphics thumbnail preview window showing 8 individual panes. There are other variables in the Page Setup dialogue box too numerous to mention but I have tried several including selecting the Printer Page radio button on the Size tab and then seeking to alter settings on the Printer Page tab. The farthest I have gotten is to have the Epson Workforce 1100 print out the 330 mm X 910 sheet but the sheet has only a small portion of the drawing contained relegated to the area corresponding to the bottom left tile. Thanks for any help with this problem and if you have alternate software that can print to this printer perhaps you would recommend that as a solution. Thanks Kevin455
Re: QuickCad 8 doc 13 in X 36 in will not print to Epson Workforce 1100
10/29/2011 2:34 AM
I don't know about QuickCad, but many CAD programs allow you to select a portion (window) of the drawing to be plotted. In this way, a large drawing can be divided into smaller parts that can fit on size A paper. Check the options under the Plot (or equivalent) command.
10/31/2011 9:48 PM
Thanks, the problem has been fixed. The settings I changed involvet the print dialog box and I set the print job to "Fit to Printer Page" and then to select the correct view, either Page View Or Extent View.
Re: QuickCad 8 Doc 13 in X 36 In Will Not Print to Epson Workforce 1100
10/31/2011 7:58 PM
I also don't know about quick cad. I had cad program in which could never print the drawing. That is untill I found the "extent" button that would let me print the whole drawing. Also before you print save the drawing after getting the "extent view" of the drawing on the screen.
Register to Reply 3 comments
Kevin455 (1); tech11 (1); Tornado (1)
