Previous in Forum: Back EMF...   Next in Forum: Transformer at VFD (AC Drive) Output
What is Cable Size for Induction Motor 30 kW Delta Star?
11/07/2011 3:19 AM
data of name plate:
pn=30kw , f=50 hz , in=64 A , vn= 380 volt
Re: what is cable size for induction motor 30 kw delta star ?
11/07/2011 3:45 AM
It depends. 64A x 1.25 = 80A.
For 30°C (86°F) ambient and 3 conductors in conduit or cable:
60° wire #3 AWG, 75°C or 90°C wire #4 AWG.
For higher ambient temperatures, or more than 3 conductors in a conduit or cable, additional factors apply, which may require larger sizes.
11/07/2011 3:51 AM
Refer BS7671-May be 16mm^2 for short run up to starter and 6mm^2 from starter to motor.
pnaban
Reply Score 1 for Off Topic
Anonymous Poster #2
Re: What is Cable Size for Induction Motor 30 kW Delta Star ?
11/07/2011 9:00 AM
As in your question For 30 kw motor , line current 64A . For star delta , six number of cables requires from starter to motor . So current in each cable will be 64/1.732=~35A . So if you use AL CABLE ,then cable size will be 35 sq mm . For copper 16 sq mm . Above cable sizes are applicable up to 50m distance.
11/07/2011 10:02 AM
→British Standard 7671.
Re: What is Cable Size for Induction Motor 30 kW Delta Star?
03/12/2024 10:47 AM
Any qualified local Electrician can sort that out. Open a dialogue. Telephone?
Anonymous Poster (1); pnaban (1); PWSlack (2); Tornado (1)
