Previous in Forum: Transformer Vector Group   Next in Forum: Oxygen Sensor and the Galvanic Cell Principle
Copper Stranded specification
04/26/2007 8:28 AM
Greetings, I am trying to locate a proper spec for a multi stranded copper conductor and its insulation properties. I am not a EE but perhaps someone out there could reduce the path I am about to venture onto?
Re: Copper Stranded specification
04/26/2007 8:34 AM
Why is this specification needed? For example, is it a cable the supplier must produce for a certain purpose? Or is it being extended up to and possibly beyond its insulation rating?
04/27/2007 8:23 AM
Try ASTM std: B3-01 as a minimum guide. Your application affects the insulation and Cu. properties you will finally require.
04/27/2007 1:47 PM
The AWG (American Wire Gauge) copper wire table gives the wire size, circular mills, weight/lb. and nominal ohms/1000 feet @ 20deg. C. That will get you started.
You can lead a horse to water but a pencil must be lead.
04/28/2007 12:31 AM
Hi
you can try with ASTM B88 you will find schdule for copper pipes ( K,L,M ) and
BS 2871 or EN 1057 ( Y, X, Z from the above standard table you can find all information you needed .
good luck
04/30/2007 9:16 AM
What is your Application: The quality of the Cu. ie percent Elongation is importan. The Temperature the cable is subjected to will guide your insulation specification. The type of product and its usage will determine the style of cable.
Anonymous Poster (2); Jawdat mustafa (1); maxmutant (1); PWSlack (1)
