Previous in Forum: Power Cable Sizes   Next in Forum: Photovoltaic Simulation
8 comments
Transformer Question
11/10/2011 8:55 AM
delta/star transformer it's delta side is connected to another star/delta transformer , star side what happened ?
Re: transformer
11/10/2011 8:57 AM
Dunno. Does it have a neutral terminal?
Re: Transformer Question
11/10/2011 12:03 PM
what happened ?
Why did anything happen?
I should have thought that nothing should have. After all when I connect a transformer at my home I don't know the distribution transformer is star connected or delta connected well I do know but I don't bother.
11/10/2011 12:09 PM
Sounds like somebody didn't have the right transformer and got creative with what they did have...
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
11/10/2011 12:38 PM
Did you say starboard?
Good Answers: 116
11/10/2011 12:38 PM
Nothing happened, except you connected two transformers together (did you connect A-A,B-B,C-C or was it a-A,b-C,c-B or another?). You have not said you have energized anything - or where!
Good Answers: 170
11/11/2011 4:56 AM
Nothing would happen as long as the delta receives line voltages from the star. In any LV electrical installation, the trafo. secondary is star connected and most of the LV motors are delta connected. We do connect these delta windings of motors to the star winding of the transformer. Did anything happen? This is also akin to that.
Good Answers: 15
11/11/2011 7:33 AM
Draw it out - delta on one side of your drg and star on the other. Label the legs / joints L1,L2 L3. Now connect L1 to L1, L2 to L2 etc. If you had transformers with a ratio 2/1 you would drop the voltage from delta to star and then in the next transformer you would lift it back up again. The current flow due to impedance would be screwed up and generally it would be a very lossy way to transmit power.
11/12/2011 12:57 AM
You didn't mention vector group and voltage ratio.
pnaban
Register to Reply 8 comments
67model (1); Anonymous Poster (1); electricalexpert65 (1); hithuanand (1); pnaban (1); PWSlack (1); silverfox (1); SolarEagle (1)
