Previous in Forum: OISD Requirement for Providing Welding Receptacles at Plant Equi. Manhole??   Next in Forum: Relay Settings
Astat
11/12/2011 5:02 AM
I've some problem regarding the hoist motion that when sometime there is freefall from hoist, but the brake and tachometer is ok.
Good Answers: 804
Re: astat
11/12/2011 9:57 AM
In your title you have the word "astat" which is a trade name for a solid state soft starter from GE. Is that what you have? If so, totally inappropriate for a hoist. The reduced torque will allow free fall, the reduced voltage messes with the brake
Re: astat
11/12/2011 1:21 PM
hi.. guru
astat is the cycloconverter product of ABB, it used for hoist motion.there is freefall that happens once or twice a week.i checked everything but unable to find the problem
Re: Astat
11/12/2011 3:23 PM
I presume you mean this. Does their technical manual trouble shooting section mention load creep or other problem movements?
Re: Astat
11/14/2011 8:04 AM
If a hoist (lifting equipment) is behaving in freefall then there is a fault. Do not use it until the fault has been rectified and the repairs inspected as satisfactory by the Engineer/Surveyor for the company that is supplying lifting equipment failure indemnity insurance cover at the facility.
Good Answers: 804
Re: Astat
11/14/2011 2:01 PM
This is why I was confused. Seems someone in one of those companies failed to investigate the trade name thoroughly!
Anonymous Poster (1); JRaef (2); PWSlack (1); Tornado (1)
