Previous in Forum: Fuse Rating Selection   Next in Forum: IEC v/s IEEE/ANSI - Short Circuit Current Calculation Designations
Earthing Current
11/15/2011 5:52 AM
when we ground current or voltage through earth conductor,where does it go when we assume potential of earth is zero?
Re: earthing current
11/15/2011 5:57 AM
11/15/2011 5:57 AM
Right straight into the ground...where else?
Anonymous Poster #2
11/15/2011 6:53 AM
Potential of the ground is taken as a reference (and hence it is zero).
In fact it may better be treated as a huge conducting sphere, with reference to which one measures the voltages.
All the generating equipments (unless it is done by some mistake) somehow or other (directly or indirectly) has one of its connections earthed.
The earth fault current passes from the user (Say you) to the huge conducting media (earth) and lands up in the generator thereby completing the circuit.
Anonymous Poster #3
Re: Earthing Current
11/15/2011 8:14 AM
Earth,Atmosphere etc are assumed as sink
Good Answers: 170
11/15/2011 8:37 AM
Back to the source neutral, thro the earth.
11/15/2011 12:07 PM
It becomes dark energy....
11/15/2011 2:13 PM
Quote" we assume potential of earth is zero?" What does that mean?
We use earth(dirt) as a zero reference point with regards to all other points that are part of the electrical system. Any voltage measurements are made between any two points with one of the points being earth or any other point electrically connected to earth.
Register to Reply 7 comments
Anonymous Poster (3); electricalexpert65 (1); SolarEagle (1); Tornado (1); wareagle (1)
