Previous in Forum: Measurment vs Protection Cores of CT   Next in Forum: Buchholz Relay Trip Signal
13 comments
Oil Rig Lighting
11/21/2011 5:25 PM
There we go, me again.
I'm having a problem or i should say that i don't know what to do to enlighten our working area. I'm talking about the main deck of an oil rig which is painted in dark grey... We added lights where ever it seem to be the best location to our knowledge without making a whole lot of head way.
I mentioned to my bosses that lighting in a science, if i can say, on it own and we should have some expert to come onboard to make a survey. But apparently one of them has been done on another rig and the result wasn't clever...
So my question are, what are the parameters i have to consider to produce an efficient light quality, or where do i start...?
I will greatly appreciate any help or tricks, reading materials etc. We are currently drilling in the North sea and in this time of the year we need light...
Regards
Just for fun!
Re: Can you enlighten up this place?
11/21/2011 5:37 PM
Go here, or some other rig light seller/installer.
Rig Lighting | Offshore - Land-Based - Rig Drilling Lighting | Rig-A-L
This can't be a unique problem.
11/21/2011 6:13 PM
thank you, Lyn.
The rig was originally fitted with Rig-a-lite fixtures, mostly 1000 watts mercury vapor. We had to removed them in location where the temperature rating was critical, where else we replaced them with three 400 watts. We tough that was going to be a solution but still not...enough or too much i don't know.
Them came the LED fixtures than we are installing all over the places, because they are small and not greegy at all. But still the same problem and even worst now the complains are about bad vision and dazzling.
Any way Thank you
Just for fun!
Re: Oil Rig Lighting
11/21/2011 6:27 PM
The first thing is to determine what work or activity takes place in each area, knowing this, then you can determine amount of lumens required in each location, what safety requirements, explosion proof, wire covered....Then survey available mounting locations, taking into consideration height of available lighting locations you can then determine wattage required..For instance a 400w HPS mounted at 20' will provide more lumens per square foot at 15'...The link provides a graph for luminosity required...
http://www.engineeringtoolbox.com/light-level-rooms-d_708.html
http://www.atslighting.com/light.html
11/21/2011 6:51 PM
Would go full spectrum if possible where ever you can...
http://www.lrc.rpi.edu/programs/NLPIP/lightingAnswers/fullSpectrum/abstract.asp
11/21/2011 8:52 PM
I've worked in specialized lighting for much of my career, including lighting in extreme environments, though nothing like oil rig lighting. So, I may be wasting your time, but here is how I see it (no pun intended):
There are generally two types of lighting, 1) diffuse lighting from a large diffuse lamp or from a diffuse reflective surface lit by a lamp, and 2) spot lighting from a single lamp or from various but separate lamps. Both kinds of lighting are usually needed, the spot lighting for a specific task area and broad area diffuse lighting. Spot lighting is brighter at the work surface but can cause bright glare spots and can be blocked by the worker or by equipment. Diffuse lighting is usually not as bright at the work surface, but it helps eliminate shadows and lights up the area around the task to help with perspective and depth perception.
In most cases, like for indoor lighting, diffuse lighting is created by putting a diffuser in front of a lamp. In a severe environment like yours, you would probably want to bounce the light off a matte white painted metal surface mounted above the workers.
Also, night vision is ruined by the blue and green components of white lighting, so you want to use warm white lighting or (even better) amber lighting outdoors as well as in the indoor areas adjacent to the outside work areas. (It does not have to be pure red as some people think.) You might even have the workers wear amber 'sunglasses' indoors at night before they go outside to help them quickly adjust to the dark.
11/22/2011 12:28 AM
Thank for your reply, you are bringing exactly what i am looking for... What is affecting the night vision, how it works? No disrespect on all the other ideas, but the worst location is close to the hazardous area zone and HPS lights are to hot...So what kind of light will give the proper colour or warnt, or is a diffuser (tinted glass maybe)?
Any way I have to go for now, but this is very interesting. I will think about it.
Thanks' a lot
Just for fun!
11/22/2011 12:44 AM
Hmm, interesting wrinkle. Fluorescents and LEDs are relatively cool; incandescents, halogen, and HPS (high pressure sodium) are relatively hot. However, oversized fixture design could reduce all of the exposed surface temperatures.
11/22/2011 8:23 AM
There is a chemical in the eye called rhodopsin, also known as 'visual purple', that aids in night vision. Bright, short-wavelength light in the UV to blue to green part of the spectrum destroys rhodpsin -- maybe 'quench' is a better term since it comes back after about 20 minutes when the short wavelength light is removed. Light in the amber to red part of the spectrum does not affect rhodopsin.
'Warm white' lighting refers to its 'color temperature', i.e., yellowish incandescent lighting with a color temperature of around 2000 to 3000 Kelvins. 'Cool White' lighting is bluish white and has a color temperature of around 5000 Kelvins or higher. HID lamps such as metal halide, mercury vapor, high pressure sodium, and xenon are examples of lamps that produce bluish or cool-white spectra. These lamps are efficient in lumens per watt, but aren't so good for nighttime lighting when careful, detailed work is required since the eye has much poorer resolution to blue light than it does to green - red light. In the fovea, the center of the eye's imaging region, there are almost no receptors for blue light, which is why it is hard to read blue text or to read text illuminated by bluish light. Here's an example (the same size text and font is used for all the lettering here):
My thoughts would be to use a number of incandescent lamps reflecting off a large metal reflector that is painted a yellow-orange orange color with a matte finish to diffuse the light. This would give a type of indirect lighting like a flat white ceiling produces a diffuse light with no shadows.
Good Answers: 58
11/22/2011 8:56 AM
Great Info
Good Answers: 21
11/22/2011 10:20 AM
Usbport is dead on with the explanation. In the painting industry such as I work in, we run into light color issues all of the time. Need to know the color spectrum your working with and then what you need to work with before hanging any type of lights. Or, like looking at paint chips in the store and when you get them it sure will look different due to lights or lighting colors.
Good Luck with the lighting.
02/01/2012 8:00 PM
Thank you for the very interesting explanation of lighting/ vision theorical. By the way sorry for the late reply, i did not think about that during my time off.
Any way, i knew or felt that a warmer light is easier on the eyes, but i'm facing to major problem. 1- The company colour is dark grey, like they seem to be all dark and dirty grey and that won't change. Secondo, my relief and co-workers have a H... on the new LED light (appently maintenance free, and they are so far).
That been said, i feel like loosing my time and unfortunatly your, in trying to find a sensible and economical solution. All they want, is looking at the electrician installing light. The good thing about this in our besiness, is that they have more money than common sense.
Thank's again.
Just for fun!
11/21/2011 11:35 PM
I would do what crab boats engaged in night fishing do: 1000-Watt sodium vapor lights. A typical setup for a large crab boat would be five on the foremast, spread out over maybe a 120° angle. An oil rig would surely use more, aimed toward the areas needing lighting the most.
11/22/2011 3:20 PM
The U.S. Navy uses red lighting when conducting top side operations at night, such as replenishment at sea and carrier ops. When doing so, care must be taken to not introduce white lighting which would destroy night vision. Once your night vision is established, most routine work can be conducted in the lower level red light without problem. I don't know if it could be used on oil rigs. It would mean eliminating white light for red lighting.
Mr.Ron from South Ms.
Register to Reply 13 comments
fixitorelse (1); KJK/USA (1); lyn (1); ronseto (1); SolarEagle (2); Tornado (2); TripppleP (3); Usbport (2)
