Previous in Forum: In Closed-loop Flow Control, What is Better? FM Before CV or CV Before FM   Next in Forum: Short History of DC Reference Standards & Calibrators
P&ID instrument Abbreviations
11/23/2011 9:02 AM
since there are many types of abbreviating the P&IDs, a huge variety of abbreviations are applied.
With no specific abbreviation or Legend, I have encountered some instruments with HTT and also AFS abbreviations.
The P&ID describes and Air Handling Unit (HVAC system) and the above mentioned devices are used at the entrance of some Fans(Blowers).
I think they shall be Switch and Transmitters, but I'm not sure. please help me to find out.
Thanks.
Re: P&ID instrument abbreviations
11/23/2011 9:10 AM
In that context, and without sight of the document, AFS could mean "Air Flow Switch", though the abbreviation itself can sometimes refer to an adjustable spanner - "Any F&£$%@ Size" - which would be out of context. That's the problem with abbreviations -particularly in CR4 - they need definition before they are used so that all readers have a point of reference.
So there should be a standard list of instrument tag abbreviations, which the P&ID originator should have used to populate the drawing. If the reference is not on the drawing then ask the originator for the route to this list in the first instance. It might turn out to be an international standard, in which case once known about it can be found using any internet search engine.
02/16/2013 9:13 AM
That's what I have notices on a lot of p&id drawings..... No legends.
Good Answers: 176
Re: P&ID instrument Abbreviations
11/23/2011 10:57 AM
It's not unusual to find that the 'scribes' who generate P&ID's adapt common terminology without necessarily providing a legend, in many cases because they're unaware that there's deviation from the standard.
I would guess that given the functions, air flow switch for AFS sounds reasonable.
Although first letter H is officially designated 'hand', could HTT be Humidity-Temperature Transmitter ?
11/27/2011 4:48 AM
thank You very Much.
Good Answers: 58
11/23/2011 11:31 AM
As PW said -this may be a good time to submit an RFI (request for information) to the engineer/system designer/drawing draftsperson.
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
11/25/2011 8:59 AM
Your know whats ironic, besides "PID" standing for Proportional Integral Derivative, "PID" also stands for Process Identification.ha ha
Also this ISA reference may be use in the future...
http://www.isa.org/Content/Microsites165/SP18,_Instrument_Signals_and_Alarms/Home163/ISA_Standards_for_Committee_Use/S_55.pdf
Useful related sources ...
http://www.smartdefine.org
http://www.acronymgeek.com/
AB PLC Training onsite, On-Line, training software and more. BIN95.com
Register to Reply 6 comments
BIN95 (1); Iris (1); KJK/USA (1); phoenix911 (1); PWSlack (1); SIAVASH (1)
