Previous in Forum: Adhesive for Bonding a Peltier to a Water Cooler   Next in Forum: Grinding Seam Weld
Flow in Accelerated Straight Circular Cross Section Pipe
11/30/2011 1:20 AM
Hi,
Could you tell me how to arrive at the flow rate possible through a straight pipe with a defined pressure difference between inlet and outlet, placed inclined to the horizontal plane and the whole pipe system is accelerating in the forward direction? I want to know the effect of inertia force (induced because of the acceleration of the system) on the flow rate.
Re: Flow in accelerated straight circular cross section pipe
11/30/2011 1:40 AM
Some pipe flow vs. pressure drop formulas include Hazen-Williams, Darcy-Weisbach, and Colebrook. One might start with those, adding or subtracting the vertical head over the distance of the sloped pipe run.
11/30/2011 3:02 AM
Yep. Incompressible flow. Darcy-Weisbach rocks!
11/30/2011 3:12 AM
Not only that; it's the easiest one of the lot!
11/30/2011 6:39 AM
Here on earth, at a constant velocity, gravity trumps inertia so there is no effect on the flow rate because of the "acceleration" of the system.
You could, perhaps, make a case that if the earth stands still the effect of gravity on the fluid inside the system would be slightly higher.
Now, if you want to consider what happens in a rocket's fuel delivery system at launch, due to the forces of acceleration, we can have a discussion about that.
Good Answers: 137
Re: Flow in Accelerated Straight Circular Cross Section Pipe
11/30/2011 7:27 AM
Using Darcy-Weisbach (as others have suggested) you need to do an iterative calculation to find flow with a given pressure difference, even in the absence of acceleration.
If the pipe is accelerating, and pipe axis parallel to the acceleration, the force seen by the fluid = M*a = L*ρ*A*a, where M = fluid mass, L = pipe length, ρ = fluid density and a = acceleration. So ΔP due to the acceleration = force/area = L*ρ*a.
You can add that to your original ΔP to put into Darcy-Weisbach.
That's my take on it anyway.
11/30/2011 9:46 AM
I'd go with that - but it's a bit more complicated if the pipe axis isn't parallel to the acceleration. Need the OP to clarify - pipe inclined to the horizontal, but accelerating "in the forward direction" - which way's forward?
(Think you missed out "A = pipe cross-sectional area").
Good Answers: 137
11/30/2011 12:42 PM
You're right, I forgot A = pipe cross-sectional area thanks.
If the pipe axis is at angle θ from the acceleration, the ΔP due to the acceleration is L*ρ*a*cos θ = L*ρ*a when θ = 0°, 0 when θ = 90°.
Codemaster (2); JohnDG (1); lyn (1); PWSlack (1); Tornado (2)
