Previous in Forum: Dent Removal procedures   Next in Forum: Fluid velocity measuring system...plzzz
Clamp Conveyor
04/28/2007 8:56 AM
Dear Sir,
We are doing Clamp Conveyor, I need Your Help
start from motor
from Motor, gear box is connected and from gear box,shaft is connected and from shaft Driven sporcket is connected i.e. Dia 1300mm and other side ideal sporcket is connected chain is there to connect the two sprocket,in chain we will hang our jobs for blasting & paintings, so total load will be around 1 ton,
Kindly Advice me which motor & gear box will be sutiable for above operation and how much load it will with stand
Rgds
Hussain
Good Answers: 114
Re: Clamp Conveyor
04/28/2007 10:58 PM
Depends on how fast you want to go & how the load chain is supported?
If the overall drive ratio is slow enough 100000:1 there's almost no lower limit!
Re: Clamp Conveyor
04/29/2007 6:51 AM
< Driven sporcket 1300mm dia is connected > You mean Drive is needed to this?
<and other side ideal(IDLEr sprocket - also dia 1300mm) sporcket is connected.
so total load will be around 1 tonKindly Advice me which motor & gear box will be >
Q1 If the conveyor chain is , horizontal ,well designed-well-lubricated it matters not much whether total load is 0,1,or2 tons. what matters is how fast you want the loaded chain to carry- 1 meter a minute? and do you want it to go and stop -and go again on push-button control?
Q2 Sorry to sound bad-but I hope this " Driven sporcket 1300mm Pitch Dia " rests on 2 well-designed bearing blocks AND has a shaft ending -Keywayed/Splined/flanged/what detailed dimension?--- You will need to tell this to somebody supplying you the Propeller Shaft to bring the driving torque from the GEARMOTOR.
Q3 Hope you have/can design space/gap/platform/Structure for THE GEARMOTOR at a safe/clean distance. Need to know the coaxial distance from Tip of your1300 dia Sprocket shaftend to gearmotor output shaftend.
Q4 420Volt 3 phase 50Hz power available?
Come back with these 4 answers to me mikemahant@hotmail.com
Rest is simple.
BR
MM
Good Answers: 114
Re: Clamp Conveyor
04/29/2007 3:13 PM
Exactly
more info needed!
& now the real question
Did the turtle survive the rocket launch
Love the avatar
Re: Clamp Conveyor
04/29/2007 9:38 PM
The turtle tries hard
Almost never reciprocated though.
Keeps going undeterred
Let's keep trying-like all engineers should
Thanks for getting tickled at the fallacy of my Avatar
Best wishes friend
mm
Anonymous Poster (1); Garthh (2); MUKULMAHANT (1)
