Previous in Forum: Motor Replacement   Next in Forum: Cable Size Calculation
11 comments
Can We Solve This Question by Mesh?
12/13/2011 5:05 PM
http://www.freeimagehosting.net/e5953
[url=http://www.freeimagehosting.net/e5953][img]http://www.freeimagehosting.net/t/e5953.jpg[/img][/url]
otomanb
Re: Can we solve this question by Mesh?
12/13/2011 5:19 PM
What's a Mesh?
12/13/2011 5:36 PM
Well, here's another nice mesh you've gotten me into!
12/13/2011 5:23 PM
Yes, it can be solved by mesh analysis. Now go do your homework or at least explain to us why you do not see how to solve this with mesh analysis.
12/13/2011 5:26 PM
Yes. Fig a reduces to Fig b reduces to Fig c. Calculate I1. Then go in reverse.
In Fig b you know what I1 is. Then determine what the other current are. You eventually get to Fig d.
12/13/2011 5:29 PM
Lyn
mesh = loop. You know it. Us older guys call it loop currents. http://www.allaboutcircuits.com/vol_1/chpt_10/3.html
12/14/2011 12:43 AM
There is a prior CR4 thread on this same problem. (Maybe with different numbers, but the method is the same.)
And also a Newsletter Challenge on an infinite variation of it:
A_ _ _. _ _ _...
B_|_|_|_|_|_...
where every line segment is the same resistance, say 3Ω, in this infinite "ladder"; what is the resistance between A and B?
12/14/2011 4:06 PM
Tornado
I vaguely recall seeing that problem. Did the answer approach zero?
Re: Can We Solve This Question by Mesh?
12/15/2011 6:42 AM
@lyn
very very difficult question sorry i cant answer it
otomanb
12/16/2011 3:34 PM
Tornado quote
"There is a prior CR4 thread on this same problem. (Maybe with different numbers, but the method is the same.) And also a Newsletter Challenge on an infinite variation of i:
A_ _ _. _ _ _...
B_|_|_|_|_|_...
where every line segment is the same resistance, say 3Ω, in this infinite "ladder"; what is the resistance between A and B?"
1/Req = 1/r1 + 1/r2 + 1/r3 + 1/rn r = 3 ohms
If all of the resistances are equal then
1/Req = N/r N = total of the number of resistors and r = 3 ohms
so 1/Req = N/r
Req = r/N
If N = ∞ then Req = 0
Any takers?
12/16/2011 4:35 PM
Every line segment both horizontal and vertical) contains a 3Ω resistance. Thus the total resistance includes 6Ω (the segments ending at A and B) plus the resistance of the remaining network. This can be taken as a hint that enables the construction of a quadratic equation.
12/16/2011 7:23 PM
That is a different problem.
Register to Reply 11 comments
Doorman (1); lyn (1); otomanb (1); redfred (1); Tornado (2); wareagle (5)
