Previous in Forum: Capacitor Explotion in UPS   Next in Forum: Can We Solve This Question by Mesh?
Motor Replacement
12/13/2011 1:00 PM
dear sir
for replacement of motor with other spare part what parameter to be same?
Voltage rating,kilowatt,rpm, frame size,base mounting any other things?
thanks alot
Good Answers: 444
Re: Motor Replacement
12/13/2011 2:31 PM
If the glove doesn't fit then you must acquit....Ooops, wrong forum.
Basically the easiest path is when all of your parameters are a match, although you could use a motor that has a higher kw rating if it fits mechanically. If it doesn't fit mechanically then you will need to modify the mounting arrangement, coupling system, etc. If it isn't a match electrically then you may have to rewire to the new voltage/current rating. Things you can't change include the rpm/frequency, lower kW rating (unless the current motor is over-sized), number of phases (unless both single and three phase are both nearby), etc.
A lot of this has to do with the load that the present motor is handling; i.e., if it's a pump or blower and you don't really care if the fluid volume is changed then no problem, if it's a piece of machinery that requires precise speed or motion control then good luck.
Reply Score 1 for Off Topic
Good Answers: 97
12/13/2011 2:32 PM
You can change any of those if you have the authority - Just prepare yourselves to be called a stupid so-and-so.
Anonymous Poster #2
12/13/2011 9:17 PM
I guess AP wanted specifically any other things?
I think what you have mentioned pretty well sums it up. Unless you have specific thing in mind (eg VFD drive then you must ask for the compatibility)
Good Answers: 181
12/13/2011 10:42 PM
Just quote the precise reference of the frame along with the RPM and electrical details to your supplier.
Good Answers: 170
12/14/2011 7:27 AM
That should do.
Good Answers: 181
12/14/2011 7:12 PM
Too simple, there's got be a better way of confusing things
Anonymous Poster (1); electricalexpert65 (1); Hendrik (1); RAMConsult (1); TonyS (2)
