Previous in Forum: Cable Size Calculation   Next in Forum: What is the Maximum % Operating Load for a Particular Generator
Wattmetric Relay
12/14/2011 12:35 AM
What is wattmetric relay, how they work?
and where they can be used?
please share!
Re: Wattmetric Relay
12/14/2011 1:41 AM
It is a directional zero- sequence active power relay.
11/15/2012 12:52 PM
I'm not familiar with a watt-metric relay (hence my query on the topic), but I'm pretty sure it would be a positive sequence element and not zero sequence.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: Chennapattanam (Coromandel Coast of the Bay of Bengal).
12/14/2011 6:58 AM
DEFINITION
The wattmetric relay is a device which receives information on the voltage (V) and on the current(I), and calculates the cos φ value.
USE
An active power relay is typically used to check the active power absorbed by an electric motor which provides direct information on the load applied to that motor. Such information is more accurate than the one given by the current value. Actually, the cosφ variations can change the power values without affecting current values marked.
12/14/2011 7:12 AM
...then it can also be called a phase-angle relay.
12/14/2011 12:09 PM
It gives you a real time readout of motor load...
11/15/2012 12:54 PM
I think you are referring to a wattmeter, not a watt-metric relay.
Register to Reply 6 comments
Colorado-Bill (2); lyn (1); mandi (1); PWSlack (1); SolarEagle (1)
