Previous in Forum: Sour and Non Sour   Next in Forum: Steam Turbine Barring Gear/ Turning Gear
14 comments
Spring Load a LCD Monitor Mount
12/16/2011 2:33 AM
I would like to spring load a vertical adjusting monitor mount.
The mount could be as simple as two square telescoping tubes with a flat plate to attach to the LCD monitor.
What kind of spring counter balance would be used?
I haven't been able to find an available low profile height adjustable mount for purchase as the fire codes restrict depth to 6".
Norm
Good Answers: 18
Re: Spring load a LCD monitor mount
12/16/2011 3:22 AM
Hi normnet,
I would consider using a "Gas Spring", it will give a more constant rate than a steel spring. The gas inside can be bled off, to counterbalance the weight of the monitor, and it could be fitted between your two guide rods.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
12/16/2011 3:46 AM
Can you explain why a fire code would be even remotely interested in this?
12/16/2011 6:36 AM
See:
https://www.cms.gov/SurveyCertificationGenInfo/Downloads/SCLetter10_18.pdf
Basiclly to maintain corridor width.
12/16/2011 4:53 AM
There are many different types for height and/or swivel configurations available...
http://www.ergomart.com/lcd_monitor_stands/lcd_monitor_stand.htm
12/16/2011 6:41 AM
The picture to the left is a start.
The mount needs to be a wall mount and adjustable by simply lifting up or down.
It appears to be OK with the 6" maximum from the wall.
Norm
12/16/2011 7:02 AM
You might have mentioned wall mount...You mean like this...
http://www.amazon.com/Buddy-Products-flexibility-horizontal-adjustment/dp/B004E3IGWI
12/16/2011 7:07 AM
<You might have mentioned wall mount...You mean like this...
Require height adjustable and no arm to keep within 6".
Norm
12/16/2011 7:40 AM
Seems like you could buy two of these, and combine them with one side bolted to wall and other to monitor...
12/16/2011 11:41 AM
Good Answers: 18
Re: Spring Load a LCD Monitor Mount
12/16/2011 9:00 AM
Hi again normnet,
Thinking about your "problem", how much does the monitor weigh and how much do you need it to move in total.
Best regards,
John
12/16/2011 8:33 PM
>Hi again normnet,
>Best regards,
>John
I'm not sure of the weight. I will try get it tomorrow.
Move total could be from 5" to 10".
This is what I am looking at at present:
One telescoping square tubing and one of the 3 listed gas springs:
Heavy Duty Telescoping-Tube Framing, 2 1/4" Stroke, 4931T145 http://www.mcmaster.com/#telescoping-tubing/=fe72fh
Gas Springs with Ball-Joint Fittings, 15 lbs. Force, 8.27" Stroke, 4138T581, page 1188
Remote-Release Gas Springs with Ball-Joint Fitting, 20 lbs. Force, 10" Stroke, 9833T31, page 1191
Reducible-Force Gas Springs with Fittings, 90 lbs. Max. Force, 7.87" Stroke, 6465K92, page 1190
The gas spring would be enclosed by the tubing.
Staff would only be required to lift up or push down to position.
I'm not sure how to hold at position however except if locking gas spring.
Norm
Good Answers: 18
12/17/2011 7:22 AM
Hi Norm,
Looks like you have got it pretty well sorted. You might need some sort of external lock, a spring loaded pad to be released to move the monitor or if the gas spring force can be set near to the counterbalance weight of the system the spring loaded stop could be made with just be enough friction to hold the screen wherever you want.
Best of luck
John
Good Answers: 266
12/16/2011 10:37 AM
Not telescoping but would give you your tolerance off the wall. If you keep the depth of the monitor to 4 inches.
Just basic drawing what you need to do to make it look good is up to you.
Good Answers: 102
12/16/2011 11:14 PM
Use a vertical weight balanced window sash.
Replace the window glass with your monitor.
Register to Reply 14 comments
jesw55 (3); normnet (4); ozzb (1); SolarEagle (4); Tornado (1); Wal (1)
