Previous in Forum: Induction Problem   Next in Forum: Vernier Caliper
9 comments
Which is More Accurate DPT or Flow Meter
12/17/2011 12:11 PM
want to measure flow in a process where pressure is 24 bar, flow is between 0 - 70 igpm. line size 2 inch medium water.
i want to measure flow accurately i have two options
1. DPT with orifice, dpt has accuracy 0.075% of reading and i don not know the what will be the accuracy of orifice plate, please tell me as well.
2. In line vortex flow meter, accuracy is 0.7 or 1% of reading, its price is double than dpt
somebody told me that orifice plate has 3- 5 % accuracy.
please suggest for better accuracy i should go for 2, or any other solution
Re: which is more accurate DPT or flow meter
12/17/2011 12:26 PM
Good Answers: 176
12/17/2011 1:34 PM
If the water is not high purity water, (de-ionized) like boiler water, then a magnetic flow meter has accuracy close to a Vortex meter, without the low flow cutoff range of a vortex flow meter at a slightly lower cost.
As a rule-of-thumb, the lower 10% of span of a vortex meter is regarded as zero flow, because of the inability to generate sufficient number of vortices at that low flow rate. So flow goes from zero to 10% (roughly) in a step function. The assumption with vortex is that the flow is not in the less-than-10%-flow-region because there is no accuracy below 10%, it's always zero.
Both mag and vortex need upstream/downstream meter runs, vortex needs longer significantly longer meter runs than mag.
The line pressure requires a tube that will hold that pressure, but all the major manufacturers cover that pressure range.
Clamp-on flow meters don't care about pressure and work well on uncorroded pipe.
The accuracy of an orfice plate drops off dramatically at lower flows. The flow is not automatically zeroed, but accuracy goes off the map. See Spitzer's article here for a summary of orifice plate accuracy (Spitzer wrote the book on flow)
http://www.flowcontrolnetwork.com/measurement/flowmeters/article/accuracy-of-orifice-plate-differential-pressure-flowmeters
12/17/2011 1:41 PM
It seems that someone "in the know" has spoken.
01/17/2012 6:38 PM
Orifice plates and DP transmitters are used because of thier relatively low cost when compared with other flow measurement instruments and because a DP TX can be transferred to a level or pressure scenario, it generally cuts down on the amount of spares that need to be warehoused. It's all an exercise in cost! If you want greater accuracy at those kind of flow rates with a medium like water, a low cost solution is a turbo impellar type flow meter. Very basic, very reliable, and easy to maintain. Hope this helps!
An educated man is not necessarily knowledgable, but has the intellect to call upon his resources.
12/17/2011 4:54 PM
How about a volume positive displacement meter, similar to those at fuel stations?
Re: Which is More Accurate DPT or Flow Meter
12/19/2011 8:58 AM
As it has already been said if accuracy is your goal a magnetic flow meter is an inexpensive and effective means of measuring flow of a liquid that is conductive... Accuracy can be as good as 0.25% of flow rate. Process dependant.
For example:
http://tinyurl.com/cyuvb9a - Siemens
http://tinyurl.com/cken5eg - E+H
If You need better accuracy or if you are flowing a liquid that is non-conductive and the line size is less then 10-8 inches the best way to go is a Coriolis flow Sensor.....
The accuracy can be as good as 0.10% of flow rate.
For example:
http://tinyurl.com/7nmfpcw - Siemens
http://tinyurl.com/75zlmbk - E+H
Accuracy is just a matter of money how much do you need is up to you.
Cheers,
12/19/2011 10:18 AM
What is the line material?
What is the purpose of this water, i.e. what is it going to do when it arrives at its destination?
Good Answers: 19
12/19/2011 12:45 PM
Flowmeter!
Register to Reply 9 comments
Ducdude (1); Iris (1); lyn (2); PWSlack (1); SolarEagle (1); Stedou73ish (1); Tornado (1); wopx8z (1)
