Previous in Forum: Method of Lightning Protection of Movable Machines on Port   Next in Forum: AVR Changing with Different Type
Per Unit Fault Calculation
12/19/2011 4:59 AM
what is the differance between
per unit fault calculation or fault calculation?
Re: per unit fault calculation
12/19/2011 5:05 AM
At first glance, the words "per unit".
India - Member - New Member
Good Answers: 164
12/19/2011 6:40 AM
Try here
Re: Per Unit Fault Calculation
12/19/2011 1:00 PM
One's expressed in PU units (a unit-less expression related to the system), the other in units such as amps, volts and VA.
12/19/2011 5:11 PM
The per unit method is a way to make fault calculations.
Good Answers: 444
12/19/2011 9:55 PM
The difference is the amount of time it takes to get the answer. It is easier to calculate the current through a reactance as 1/.05 and see that the current is 20 times the base current; rather than work with the actual phase to phase voltage, convert it to line to ground, divide that by the actual reactance in ohms to get a value in Amps, and then figure out how much greater than normal the current is. It is also how properly trained Power Engineers can spot wannabes during an interview.
jack of all trades (1); kvsridhar (1); PWSlack (1); RAMConsult (1); wareagle (1)
