Previous in Forum: Broadband Network Towers   Next in Forum: Christchurch NZ Hit Again by Earthquakes
11 comments
Hobbies - Hunting - New Member
Pool Temperature
12/22/2011 10:29 PM
is a round pool warmer than a square one in the sun
Pathfinder Tags: sun efects
Re: pool temperatur
12/22/2011 10:32 PM
No. Don't be silly.
Re: Pool Temperature
12/22/2011 11:54 PM
Actually...
It depends on whether the pool is warmer than the ground temperature that surrounds it. If it is, a square pool of the same volume and depth as a round one will have greater surface area in contact with the ground, and therefore will lose heat more rapidly.
(And other combinations of what is warmer than what else. Above ground versus below ground could make a difference, as could air temperature. Aha, the next student who needs a graduation project could thrash out some of these possibilities.)
12/23/2011 7:57 AM
All other things being equal, solar radiation doesn't care about the shape of the pool, only the amount of surface exposed to the sun.
12/23/2011 1:02 AM
this is a question that was pu up as a theory of an local eng he said the sun rays in a round pool do bounce around and heat more.....I dont know thats why ask silly or not if I get a reasonable answer I will thank you very much
12/23/2011 1:05 AM
Sounds like the local eng is talking bubcus to me. Tornado's answer has merit - GA from me.
12/23/2011 1:15 AM
thats what I think but wanted to confirm my ignorant opinion thank you
12/24/2011 12:22 AM
a round pool might reflect sunlight into the water for a longer time.
12/24/2011 3:58 AM
yes and.......
12/24/2011 4:11 AM
...no (to complete the thought).
12/24/2011 8:24 AM
Reflect...................from where? Once the solar energy strikes the surface of the water and the wavelength changes the work of heating is essentially done.
12/24/2011 8:39 AM
if I paint the bottom dark . is this water warmer than if painted white, it seems to me the surface does not stop the heating process
Register to Reply 11 comments
ajwinemaker (1); Anonymous Poster (1); bernard de raadt (4); lyn (3); Tornado (2)
