Previous in Forum: Starting of Synchronous Motor Using Cycloconverter and Converter   Next in Forum: Trouble On Variable Frequency Driver
Causes of Tripping?
12/25/2011 5:01 AM
Two 132Kv feeder from Substation - A & Substation - B was feeding to substation C by underground system. one of the feeder (A to C) got damaged by external source. due to this damage feeder (B to C) got tripped and Substation C become blockout for 1 hrs.
What is causes of tripping in feeder B to C? how to avoid this in future?
Re: Causes of Tripping?
12/25/2011 5:17 AM
Reply Score 1 for Off Topic
12/25/2011 9:32 AM
Tripping may be caused by over loading due to damage to A to C feeder. Get that fixed.
Tripping may be caused by overindulging in alcohol, too.
Hire a competent electrician to evaluate it and fix it. If you have to ask, you can't fix it.
132kv will turn you into a crispy critter very quickly.
12/25/2011 11:50 AM
One way or the other, Lyn, you're close to the root cause here. Hopefully, the actual problem is that this student has already overindulged in alcohol and is now tripping over this homework assignment given during a school break. There is also the disturbing possibility that a power utility has hired people to design their network that know nothing about power grids.
Good Answers: 70
12/26/2011 8:25 PM
I have to agree with both you and Lyn. And this does sound like hypothetical home work scenario I often wonder about these AP posts
12/26/2011 12:28 AM
In order to know the cause of tripping, first you must check the protection which operated, i.e earth fault relay, overcurrent, differential etc and then start from there. The damage caused by external source is not detailed and I can only assume that there may have been a damage due to excavation, in which case the earth fault relay has operated on both feeders. It would be normal for the feeder from substation A to trip as the fault was direct. The tripping of feeder from substation B is not evident but it can happen, especially if the transformer neutral is connected to earth through an impedance. The problem can be avoided but one must have the full details of the distribution network to work it out.
12/26/2011 12:38 AM
THANX FOR UR REPLY ,
12/26/2011 12:53 AM
Can you confirm if the earth fault relay has operated on both feeders, and can you give details of transformers connected on both feeders.
dj95401 (1); guest6 (1); Kiscal (2); lyn (1); redfred (1); Tornado (1)
