Previous in Forum: Static Excitation System n-1 Critrion.   Next in Forum: Inverter Calculation
Battery Autonomy
12/26/2011 8:52 AM
i want to know what is meant by term "battery autonomy" when referred to UPS system.our 400VAC to 110VDC UPS system literature contains the term:
battery autonomy = 60 minutes
now what does that mean?
thanks in advance .
Re: battery autonomy
12/26/2011 8:57 AM
It sounds as though the UPS will support the load for 60min without its being connected to the power supply. Does that make sense, given the context in which the statement is made?
Re: Battery Autonomy
12/26/2011 12:17 PM
PWSlack is correct (as usual).
http://www.upspower.co.uk/ups-products/choosing-a-new-ups/ups-technical-glossary.aspx
That search took all of 30 seconds. You should try it sometime - before posting.
12/26/2011 3:47 PM
How difficult can it be to apply some simple logic here???
Or, as you say, discover the answer on one's own.
Maybe ask a teenager, he'll know.
12/26/2011 4:41 PM
Autonomy
Also known as back up or discharge time, battery autonomy is a measure of the time for which the battery will support the critical load during a mains failure. Autonomy is a function of battery charge state, capacity and load size.
That wasn't too tough, was it?
Register to Reply 4 comments
Kilowatt0 (1); lyn (2); PWSlack (1)
