Previous in Forum: Can We Rotate Tangential Bar Rotor Motor in Both the Direction   Next in Forum: Leakage From Transformer Secondary Bushing
Switchyard Gravel
12/27/2011 8:35 AM
substation switchyards surface is often covered with small sized stones (mostly gravel type ).what is the technical reason for it ?
Good Answers: 58
Re: Switchyard Gravel
12/27/2011 8:51 AM
C6 crushed stone is cheaper than concrete!
Good Answers: 170
12/27/2011 9:02 AM
To increase the tolerable step potential and tolerable touch potential. Pl. refer to IEEE 80.
Good Answers: 244
12/27/2011 9:30 AM
In addition, it also helps retarding the evaporation of moisture from the topsoil layer underneath the gravel during dry weather condition. This eventually helps to maintain better grounding resistance (low ground resistance).
Refer to section 7.4 and 12.5 of IEEE 80.
- MS
12/29/2011 12:03 PM
To avoid vegetation and growth of grass.
Dhayanandhan.S
12/30/2011 6:39 AM
Snakes will make shot circuit in the switch yard. As snakes are not able to move on the small stones so gravel(small stones) is provided. This is also one of the reason.
dhayanandhan (1); electricalexpert65 (1); KJK/USA (1); msamad (1); pvcr4 (1)
