Previous in Forum: Three Roll Bar and Plate Bending Machine Design   Next in Forum: Hydraulic Oil
How To Design Plug For Tube Heat Exchanger
01/11/2012 11:02 AM
dear all,
i have a tube ID - 14.85mm. i would like to fabricate a plug to plug the leak tube. how to design it? anything that i can refer to?
thanks
Re: how to design plug for tube heat exchanger
01/11/2012 11:10 AM
They got em here...
http://www.tubeplug.com/
01/11/2012 11:19 AM
In the latter days of steam locomotives, leaking boiler tubes would be "fixed" by filling them up with cement.
Good Answers: 16
01/11/2012 2:02 PM
Never thought of that cement approach???? I've made plenty of brass tapered plugs and also purchased loads from McMaster Carr. But in a big pinch I suppose a cement or even a resin would work out fine.
On that note I could see using a resin like chock fast orange or something similar
Re: How To Design Plug For Tube Heat Exchanger
01/13/2012 9:08 AM
Normally tube plug design is given by the heat exchanger manufacturer. Plug should be such that if tube get snap beyond tube sheet, it shall be retained in the same position and should not cause damage to other near by tubes.
Good Answers: 16
01/13/2012 9:21 AM
Just have a look at what Solar Eagle has provided, they have very good small diameter plugs in that link that are even easily installed with a crescent wrench.
GA SE
But oranje24, this is not rocket science and a typical plug design as seen in the Solar Eagle link for boiler plugs works just fine in smaller diameters as well, it should be a very slight taper to ensure it applies pressure to the tube sheet and not just the tube end itself. Its really just common sense.
Good Answers: 67
01/18/2012 3:37 AM
We plug leaking tube by pushing and hammering a tappered plug made of copper about 30 mm long and average dia same as tube ID and bigger dia is 1 mm more than it. After hammering about 5 mm length is produding outside. It works successfully.
Register to Reply 6 comments
Mukesh0861 (1); pritam (1); PWSlack (1); SolarEagle (1); Tim in Mexico (2)
